  • Guests: 68
Hard Drive Components.
Mon Feb 22 2016, 03:30AM Print
I need to ask what the proper term is for the motor that swings the HD arm. is it a linear motor, despite radially swinging an arm ?
johnf
Mon Feb 22 2016, 05:56PM
I though it was a voice coil
Mon Feb 22 2016, 07:41PM
Actuator that moves the actuator arm around the actuator axis.
Signification
Mon Feb 22 2016, 11:15PM
...sort of a reverse coilgun. A movable flat coil in a strong permanent magnetic field is swung on that axis by controlling the current through the coil. A quick look would say it all...
Tue Feb 23 2016, 12:57AM
extrct from Wikipedia HARD DISK DRIVE article Link2
"The actuator is a permanent magnet and moving coil motor that swings the heads to the desired position. A metal plate supports a squat neodymium-iron-boron (NIB) high-flux magnet. Beneath this plate is the moving coil, often referred to as the voice coil by analogy to the coil in loudspeakers, which is attached to the actuator hub, and beneath that is a second NIB magnet, mounted on the bottom plate of the motor (some drives only have one magnet)."
to me it is a (curvi)linear motor
I used to service mainframes in the '80s and a trolley carrying 19 heads was moved in and out of the spinning disks by a HUGE voice coil assembly, just like a loudspeaker voice coil on steroids.
Tue Feb 23 2016, 01:09AM
I think it fits into the category of "voice coil motor" or "voice coil actuator",
and the moving-coil subcategory (as opposed to moving magnet).
VCAs with moving coils are ideal for many limited-angle rotary applications that require high acceleration. The fast acceleration capability is achievable by minimizing the moving mass, in this case, the moving coil. Since it is separate from the magnet, it is customizable to be more lightweight than the heavy permanent magnet field assembly, allowing extremely fast speeds.
A limitation of moving-coil designs is the need for flexible coil connecting wires (or brushes).
The flexible connections in hard drives must be designed for some number of elastic bending cycles,
as are the flexible connections to cylindrical voice coils in loudspeaker elements. smile
Tue Feb 23 2016, 03:16AM
Sulaiman wrote ...
. . . (curvi)linear motor . . .
I like this term, but I see it might be a voice coil as you all say.
Pinkamena
Tue Mar 01 2016, 07:00PM
Pinkamena Registered Member #4237 Joined: Tue Nov 29 2011, 02:49PM
Interesting, what a strange name. I've also always wondered at how precise it must be! Quite amazing little things.
Tue Mar 01 2016, 07:07PM
Always wondered why they don't use some variant of an acoustic drive, similar to a caterpillar focus on a camera.
Would make a lot more sense than voice coils, and draw less power with the head(s) the only thing connected.
Hazmatt_(The Underdog)
Wed Mar 02 2016, 02:06AM
Positioner.
