  • Guests: 60
Direct feedback Single-FET E-klasse SSTC: 9" sparks
Antonio
Mon Dec 07 2015, 12:21PM
The schematic looks wrong, with an inverted zener, inverted bipolar transistors, and a mosfet connected just to a capacitor.
Tue Dec 08 2015, 04:24AM
Agree'd on the zener being backwards and BJTs should be swapped. However, the fet (VT3) serves as an interrupter by disconnecting the 150V return path. I believe it's connected correctly.
Perezx
Tue Dec 08 2015, 10:12AM
Perezx Registered Member #54263 Joined: Thu Jan 15 2015, 09:54AM
Sorry for zener, forgot to mention: I had no symbol for TVS, so put ordinary zener, having in mind to edit it in Photoshop.
Actually it is 1.5ke15 and it does not matter how to put it in schematics.
About BJTs - I hardly remember actual wiring, probably you're right.
VT3 is an interrupter and disconnects oscillator's GND
Benjamin
Tue Dec 08 2015, 05:04PM
Benjamin Registered Member #54655 Joined: Thu Mar 19 2015, 05:56PM
I have seen this circuit used with wildly varying values for r5 and r6, how do they affect things?
Perezx
Fri Dec 11 2015, 03:11AM
Benjamin wrote ...
R5 and R6 are setting initial gate voltage, so they affect only the starting and the only thing that matters is proportion R5/R6.
