  • Guests: 55
Inducktion (32)
Standa (31)
nabzim (33)
12/21 Inducktion (32)
12/21 Standa (31)
12/21 nabzim (33)
Was 14V LED question
first  3 4 5 6
Bored Chemist
Tue Oct 06 2015, 07:57PM
Uspring wrote ...
BC:
We're looking at the same diagram. The lower black data points seem to indicate a levelling off. From the data alone it's not completely convincing. There is a theoretical reason for levelling off, though. At lower currents, i.e. lower voltages, the fraction of electrons with enough energy for a light emitting transition is smaller. Correspondingly more electrons will lose their energy by non optical decay. At some voltage the ratio won't change much more. I'd expect levelling off at voltages (currents correspond to these) scaling with k*T.
It's a pity they didn't get more data for the 25C measurements at low currents.
I think there's probably a lot of common ground between our viewpoints.
I think that an electron has to be excited enough by a combination of thermal and electrostatic energy to get over the barrier, "fall" down and emit light.
The data show that, at low voltages , not many electrons have enough energy to get over the barrier so there's not much current and not much light. Raising the voltage or the temperature increases then number that can make the jump.
All fascinating stuff, but there's still no clear threshold and if there is one, it's well below the voltage quoted for LEDs' "thresholds".
As I said earlier (and produced the data to show it) the current vs voltage curve is smooth over that range, and follows the mathematical model for the process.
Tue Oct 06 2015, 10:12PM
Bored Chemist wrote ...
I respectfully disagree. In my opinion, two electrons need to move before a photon can be emitted. first, a hole needs to be injected into the lattice. this requires the removal of an electron. Any electron with enough energy to get over the (possibly reduced?) barrier then has a hole to fall into. (I've put this as simply as possible)
Uspring wrote ...
I think what you are suggesting is exactly what is observed in an electro-polishing tank. (I mentioned earlier I was working on a theory, as none of the textbooks I read could explain it). Above the plateau one process occurs, below the plateau another process occurs. I know the machanisms for each process must be different. I have a theory, but I'm trying to learn what I can from this thread before I try to put it into words.
EDIT: In the EP tank graph, it's current plotted against voltage, though. The current plateau at the transition.
Uspring
Wed Oct 07 2015, 09:00AM
In a strict sense you are right. In this sense LEDs are really never off solely also due to their thermal radiation. The papers main point is about the region, where quantum efficiency is bigger than 1. There light output is 69pW and thermal output in the same wavelength range 40nW, i.e. about 3 orders of magnitude more. So a careful background subtraction had to be made. By any practical means, the LED is off there. Users of blue LEDs will generally agree, that their LEDs are "off" at 2 V, even though, in the above strict sense, they are wrong. Just a matter of definition.
The doping on the p side of the semiconductor creates vacant states into which the electrons can fall into. The electrons there eventually do have to be carried out to the diodes connectors. Otherwise a charge would build up there.
Wed Oct 07 2015, 02:07PM
Uspring wrote ...
Exactly. These sites have to be vacant before another electron can 'fall in'. In some ways this process can by compared to the base-emitter channel of a BJT, which, it can be demonstrated, takes time to 'switch off'. In a BJT, collector current continues to flow , presumably until all these 'sites' are full?
Bored Chemist
Wed Oct 07 2015, 07:34PM
Ash Small wrote ...
Uspring wrote ...
Re."In my opinion, two electrons need to move before a photon can be emitted. first, a hole needs to be injected into the lattice. this requires the removal of an electron"
Actually, an awful lot of electrons need to move- one leaves the negative terminal of the battery and it takes the place of one that has moved along a bit, which takes the place of one that has moved along a bit... and so on for a zillion electrons, all round the circuit.
However, the "two" electrons you are talking about don't flow past the same place at the same time, so they are part of just 1 electron's worth of current.
Wed Oct 07 2015, 10:04PM
Yes, but one has to move first. The hole can't be injected until the current starts to flow. The site must be vacant before the second electron can be attracted to it, surely?
Bored Chemist
Thu Oct 08 2015, 06:44PM
It's being "attracted" to the positive pole of the battery.
The point is that it's still like having a string of beads. If you move the string so that 1 bead passes a point each second then it's 1 bead per second, no matter how long the string is.
Thu Oct 08 2015, 08:38PM
I get that. I also know that most textbooks are pretty vague and simplistic, to the point that they use words like 'threshold' wink
I'm just trying to understand exactly where the various forces involved are actually applied. for example, any electrons with sufficient thermal energy will be able to jump backwards and forwards over the junction, if there is no attractive force from a hole in the valence band. The energy released upon re-combination is dependent on the forward voltage of the LED.....I think I'm getting a better picture now.
Bored Chemist
Fri Oct 09 2015, 05:44PM
There is an old joke about a man running from the police who jumped over a low wall in his attempt to escape; and found that, on the other side it was the rather high wall of the local prison.
The police arrested him in the prison hospital.
Only one side of the pn junction is at ground potential.
Fri Oct 09 2015, 10:24PM
Is there no conduction band on the other side, like in a BJT? Don't they have to cross the junction THEN fall from the conduction band to the valence band?
first  3 4 5 6
