  • Guests: 52
TDK Ceramic "Doorknob" Capacitors For a Tesla Coil
nzoomed
Tue Oct 20 2015, 04:18AM
Ive just ordered my CDE 942 series caps, 40 of them (5 in series x 8 in parallel) this will give me a bank rated at 10KV which should be sufficient if i pushed my coil up to 1000APK.
Anyway, ive been browsing alibaba, and i know these are chinese, but for the price, they should be worthwhile testing for tesla coil use, since the manufacturer claims they are suitable.
Sometimes the stuff out of china is not always that bad, IDK, but im interested to try them, these are rated at 60A each!
There are many other types listed there also, im interested if anyone has experimented with chinese caps.
Tue Oct 20 2015, 06:18AM
nzoomed wrote ...
Your MMC plan sounds fine for 1000A.
About the Chinese capacitors... Package Type: Surface Mount mistrust
Their datasheet seems to be specified for 1kHz/10kHz, I would like to see atleast some 100kHz figures. Link2 and Link2
They do specify Dissipation factor: Geasured at 1000±20 Hz AND 25±5℃. When Cr≤1.0µF, 4×10-4; When Cr>1.0µF, 6×10-4, the characteristics of polypropylene is rather linear, but only up until 80kHz, then it starts going up.
A proper field test is surely needed but on the other hand, the pricing is just around where you can find proven surplus caps.
nzoomed
Tue Oct 20 2015, 10:47AM
Mads Barnkob wrote ...
Yes i agree field testing is the only way to know for sure.
There are countless other capacitors on alibaba too for various prices.
If you know of any suppliers of eurofarad doorknobs, im keen to know. They seem to be thin on the ground.
[/quote1445338071]
Hydron
Tue Oct 20 2015, 03:09PM
Big plus with the chinese is shipping is normally reasonable to places US sellers are too lazy or charge too much to ship to (e.g. NZ).
Could be an interesting option for mid sized coils, (~1kA peak), where a single series string might work okay for a rather low total price.
Aliexpress is probably easier to deal with if anyone wants to give it a go!
nzoomed
Tue Oct 20 2015, 09:25PM
Hydron wrote ...
Yes i agree, i didnt see those particular caps on aliexpress, but there is alot to choose from.
Would be great to see some reviews on them, shipping from china is so cheap its not funny.
I need a couple of aerovox snubbers and the shipping is going to cost me 3 times as much to get them here to New Zealand!
There is also tons of cheap variacs on alibaba, (not all chinese, some are from india)
I know most chinese variacs are crap, but if you buy a larger one than what you plan to use, you might get away with it.
Hazmatt_(The Underdog)
Wed Oct 21 2015, 01:09AM
For a few dollars more each, you could buy capacitors that will not burn up, EVER.
Anything with a high uF value in that form factor is going to be a rolled film capacitor, which will eventually fail.
That's just my opinion though.
nzoomed
Wed Oct 21 2015, 03:29AM
Those capacitors in your link are far too low for tesla coil use, i would need tons of them to build a decent MMC around 0.25uf, in fact even if i had the money, i wouldnt fit that many caps on my coil.
Interestingly, the eurofarad doorknobs are rolled film also and are rated at only 2KV each, so lets assume these chinese caps only realistically can rate up to 2KV and not the 4KV they claim, then you might get somewhere with them, who knows, they might work better than you think.
