  • Guests: 115
EI Transformer Laminations / Core Source
Part Scavenger
Mon Jul 13 2015, 03:01AM Print
Do you guys have any idea where to get EI Cores? I'm making a couple small custom transformers. I can't find anybody that sells them on the Internet, unless I want to wait for a shipment from India or order large quantity.
I don't want to use MOTs because I need the screw holes, and I don't need a cross sectional area that large. I don't have any other transformers I want to tear down.
I've also tried eBay, Amazon, mouser, with no luck.
Thanks
Mon Jul 13 2015, 03:51PM
mister_rf Registered Member #4465 Joined: Wed Apr 18 2012, 08:37AM
IMO modifying some old transformer is the optimal solution.
Try for example here:
maybe they are offering discounts. shades
Later edit
also see here:
Mon Jul 13 2015, 04:32PM
As far as I'm aware, we, in Europe, have to import our laminations from USA, as we don't have our own suppliers anymore.
I think there are a couple of US companies. I'll try and find out who and where they are.
radiotech
Wed Jul 15 2015, 04:09AM
Just what size core do you want? If you are after very small, ie wall wart size, up
to about 15 watt, go to a thrift shop. They usually have a bin of adapters for
50 cents each. Most aren't potted.
Part Scavenger
Sat Jul 18 2015, 04:22PM
I intend to make a transformer with about 12 sq cm core area and up. I think I'm just going to cut them myself and see what happens. The worst that will happen is it will saturate earlier than I expect or get too hot. Going to try getting some 1/16" steel from the scrapyard and see how bad the eddy currents are if I build it a little big and keep my field strength about .8 Tesla.
Also, I was on a battleship the other day, and noticed that most of the transformers are made like the attached which would be a pretty feasible option with MOT sections.
1437236497 79 FT172135 Photo
GrantX
Sat Jul 18 2015, 05:34PM
Part Scavenger wrote ...
That's very interesting. I assume it's a forced air cooling system to guide the airflow through the windings? Any idea what the transformer's job is?
When I rewound a MOT for use as a mini spot welder I found that the magnetizing current was pretty bad (3.5A or more), due to my method of assembly. I cut the original welds, removed the shunts and rewound the secondary, then simply placed the two core halves back together (with a 5kg weight on top) and re-welded them with my MIG. Afterwards I noticed there was an approx 0.25mm air gap, despite the weight used while welding. I guess it was caused by thermal stresses or the welding current / feed rate was a little high. If I had clamped the core in a vice I might have gotten better results, but unmodified MOTs already have large magnetizing currents.
1/16" (1.5mm) is probably a little thick for the laminations, but if your design doesn't require a low magnetizing current, or is only for intermittent duty, you might get lucky.
Sat Jul 18 2015, 05:35PM
Try looking on Ebay for a cheap, big, old transformer, and rewind it. It will probably cost less than steel from a scrapyard, which will be pretty useless unless it's under 0.5mm thick and is alloyed with silicon.
Hamfests are also good places to pick up big, old transformers for next to nothing. At the last hamfest I went to people were giving them away for nothing.
Carbon_Rod
Sun Jul 19 2015, 12:58AM
If you are trying to do something unique, than perhaps a local water-jet cutter service can help.
For low frequency stuff, the FEMM cad material models do seem to work rather well.
On craigslist one can usually find cheap welders, car battery chargers, and old 3-phase commercial stuff.
Your local recyclers/scrap yards will tend to charge a premium on anything containing copper, but regularly get a few kw+ step-down transformers.
Perhaps you may be located near a company like this:
Cheers,
Rod
Sun Jul 19 2015, 09:25AM
...Going to try getting some 1/16" steel from the scrapyard and see how bad the eddy currents are if I build it a little big and keep my field strength about .8 Tesla. ...
Give it a shot. How are you going to cut the sheet into E's and I's?
Have you considered using steel sheet intended for roofs, gutters, or flashing? Link2
It's much thinner than 1/16" and usually comes with durable paint on both sides.
Even if you match the thickness of conventional transformer laminations, I bet that ordinary steel material will make a much lossier transformer. I tried it once, when I was new to the 4hv forums. Link2
Lower permeability. Much higher coercive force and hysteresis loss. Much lower electrical resistivity, so more eddy current loss. Here is one brochure about transformer steel. Link2
Dr. Slack
Sun Jul 19 2015, 09:52AM
Making your own transformer laminations from random steel sounds like one of those tasks that you really don't want to do. There's so much technology in a decent lam, thickness, insulation, several magnetic and resistive properties, that a transformer made from nails or angle-iron is going to be little more than a science-fair proof of principle demo item.
How about you widen your scope of where to get a rewind candidate? Almost any mains powered boat anchor Link2 will contain a transformer. With SMPS replacing iron and halving the weight of all sorts of things, a lot of stuff is being obsoleted, try skips outside factories.
I've always found Es'n'Is very difficult to rework, if you can find C-cores they are sooo much easier
If I read your OP right, you don't want to drill holes in MOT laminations, but subsequent posts suggest you are prepared to make something inferior from scratch?
