  • Guests: 34
do magnetic flux lines rotate or no
Wastrel
Mon Apr 27 2015, 07:57PM
Wastrel Registered Member #4095 Joined: Thu Sept 15 2011, 03:19PM
To do work the conductor must cut across the flux.
Salvador
Mon Apr 27 2015, 09:03PM
Salvador Registered Member #54402 Joined: Mon Feb 02 2015, 11:09PM
or the flux must cut the conductor as in AC generators where magnetic poles rotate by stationary coils.
the only difference here is that I dont have poles on the rotor instead the whole rotor is a single pole at any given moment in time , but since its flux is AC the poles change repeatedly with a given frequency so then the question is does the flux lines cut the stator coils or do they need a physical rotating pole to do that , this question is still open.
Wastrel
Mon Apr 27 2015, 09:23PM
The flux cutting the conductor is not a different situation, it is the same one from another point of view.
You have asked an either/or question in which both answers could be wrong. If when powered with DC your system does not induce any EMF at any point in the cycle, then it will do no work powered with DC or AC.
Salvador
Tue Apr 28 2015, 10:45AM
Ok I think I got it , for this to work it would need to have poles on the rotor , or atleast a single pole but with differences in the flux at some places , which would correspond to not a solid rotor geometry.
Well I have another question then, before I mess up another thread maybe I can just ask it here.
Could a faraday disc (homopolar) generator work with a rotary transformer used as the current path from the rotor to stator instead of brushes, or slip rings, if we use a changing magnetic field as the discs field source ofcourse?
Signification
Tue Jun 16 2015, 12:16AM
I don't know if it will help here, but have you looked at Tesla's rotating magnetic field. There was a spinning egg application here...forgot the title.
