  • Guests: 42
RateReducers QCW DRSSTC
Goodchild
Tue Apr 28 2015, 01:56AM
RateReducer wrote ...
Hi Eric. Thank you!! smile
I got the caps from a member of a german high voltage forum.
The label says "MATROC 5000pF 20kV" - pulse rated caps
If you want i could contact the member - maybe he got some caps left over.
No need to bother him, I was just curious if you had gotten them through a retailer. I have been on the lookout for some nice MICA caps. I have some sitting around but they are not exactly what I want. I was hoping to find some larger caps like 10 or 20nF @ 10Kv or something like that for the next QCW I build.
RateReducer
Tue Apr 28 2015, 08:46PM
RateReducer Registered Member #4603 Joined: Wed Apr 25 2012, 07:33PM
Testing higher BPS. Bridge gets a bit warm, maybe 30 degrees. MMC, primary coil and the topload (!?) also get a bit warm.
Ramp is still a bit more than 300V even with 360VDC input - need to change the buck for higher ramp voltages.
