  • Guests: 32
marko666 (58)
12/16 Will T (16)
12/16 william L (29)
12/16 Tipiment (62)
Flyback transformer questions
first  2 3 4 5
Antonio
Tue May 05 2015, 01:15AM
Probably the pin that is arcing is the ground pin of a high-voltage capacitor connected to the main output. If you connect it to the ground pin you will get instead of the arc a series of powerful (and dangerous) sparks. You can insulate it with hot glue.
first  2 3 4 5
