  • Guests: 34
Royer SSTC
Teodor Zafiroski
Sun Apr 12 2015, 07:30PM
Teodor Zafiroski Registered Member #48007 Joined: Wed Jun 18 2014, 01:00PM
I was able to fire up this circuit today, and got some incredibly small output, the circuit draws just over 500mA at 12V, I think that's because of the 3.5+3.5 turns on the primary, I need to reduce it to about 1.5+1.5 when I connect all of the caps in parallel, that should give me a greater power draw... Here's the schematic:
And here's a video of it in operation:
When I get my hand closer to the coil, the extra capacitance pulls it in tune and the tube lights up, the spark to my fingers is so hot that my fingers began smoking, the burns don't hurt though...
I need to reduce the primary turns, connect the tank caps in parallel instead of series, and that should result in larger sparks, and hopefully- streamers!
P.S. When I place the link to the youtube video in a youtube tag, the video won't load.
hen918
Sun Apr 12 2015, 07:33PM
I think it would be a good idea to use a chicken stick and not put your fingers that close...
Teodor Zafiroski
Sun Apr 12 2015, 07:35PM
We're talking about really low powers here... I use a chicken stick whenever I work with higher powers...
dexter
Mon Apr 13 2015, 10:23AM
i tried this setup too but 2+2 turns and at 36V from a 150-200VA transformer and got 10mm streamers output
the primary was not in tune with the secondary ~200KHz primary 250KHz secondary
the mosfets got wery hot after a few second of operation
Teodor Zafiroski
Mon Apr 13 2015, 11:44AM
2+2 turns at 36V? That explains a good part of the heating, and at that frequency with that much turns and at that voltage I expect the current draw to be large, have you measured it?
dexter
Mon Apr 13 2015, 03:28PM
did no current measurements because i just slapped the parts together to see how it performs....
i used the same Royer to overdrive flybacks at 36V about 30A without much heating of the mosfets but the frequency was much lower 30-40KHz
1428938736 42796 FT170053 Zvs
Sigurthr
Mon Apr 13 2015, 10:25PM
Unexpected or excessive FET heating almost always comes down to one or more of three causes:
1) Running in the Linear region from insufficient or incorrect gate drive.
2) Shoot Through / Crossconduction from inadequate gate drive dead time.
3) Avalanche Conduction from exceeding BVds. Inductive kicks on turn off of each leg can cause massive heating effects without instantly destroying the device. As such it often gets ruled out as a culprit unless measurements are done to watch the Vds and ensure no spikes are seen.
hen918
Tue Apr 14 2015, 04:49PM
Sigurthr wrote ...
Or it could be due to the MOSFET being a re-named cheaper, bad quality or otherwise fake Chinese copy.
but, if bought from a reputable supplier, it is usually safe to assume that this is not the problem.
dexter
Tue Apr 14 2015, 05:10PM
hen918 wrote ...
is not a fake mosfet i used the same setup (see picture few posts above) at 36V ~30A on a flyback, the power resistors and the windings got hot before the mosfets :)
IRFP260M's bought from a respected site
Teodor Zafiroski
Wed Apr 22 2015, 05:36PM
I calculated the number of turns of the primary for the capacitance that I had, and tested it today. I got a small brush discharge, followed by a click when I made an arc to ground and the arc was gone. The breaker turned off, and when I turned it on again it immediately turned off every time. The MOSFET's were warm to the touch, and the inductor and tank caps as well. When I removed the MOSFET's from the circuit, the measurement had shown that they had failed all pins shorted. (one of them had 500 Ohm resistance gate to source, the other one had zero resistance gate to source, but they both were shorted drain to source)
I guess they became another addition to my silicon graveyard...
What may have blown them?
1429724206 48007 FT170053 22042015043 1
