  • Guests: 55
Building my first DRSSTC - Updated thread...
orac12
Thu May 12 2016, 12:32AM
orac12 Registered Member #9879 Joined: Tue Jan 29 2013, 05:00AM
Well I haven't blown anything up with out them, but I'll install them and hopefully reduce some of my switching spikes.
nzoomed
Thu May 12 2016, 12:51AM
orac12 wrote ...
You should get more effective switching with them, and may help to resolve your issues with your coils output possibly.
orac12
Thu May 12 2016, 01:00AM
nzoomed wrote ...
orac12 wrote ...
Have had the coil up and running decently and making 2 meter streamers so far at a reduced bus voltage. Primary to secondary flash overs are stopping me from turning it up any further at the moment.
nzoomed
Thu May 12 2016, 01:15AM
orac12 wrote ...
nzoomed wrote ...
orac12 wrote ...
Thats great news!
If you are still having flashover issues, i would try raising the coil as you mention and perhaps put some acrylic sheet over the primary.
Thu May 12 2016, 05:38AM
Flashover from primary to secondary sound more like a extremely high coupling, or the coil could be badly out of tune.
nzoomed
Thu May 12 2016, 11:18PM
Im still having trouble finding suitable TVS diodes for 24V gate operation.
The closest ive got are P6KE22CA, these have a breakdown voltage start at 24.4v and the maximum clamping voltage is 35V.
I really need them to clamp at around 26 or 27V ideally, but all the TVS i see have a far lower breakdown voltage, that means it will breakdown well under 24V.
loneoceans
Fri May 13 2016, 12:45AM
nzoomed wrote ...
Those are fine. Just lower your 24V input to the UD2 to 22V.
orac12
Fri May 13 2016, 02:24AM
nzoomed wrote ...
I used some 1N5361 back to back, which is around 27V.
nzoomed
Fri May 13 2016, 03:29AM
loneoceans wrote ...
nzoomed wrote ...
I cant easily do that as im using a transformer, i could rectify it and use a voltage regulator i guess to feed 22VDC into the DC input.
Justin
Fri May 13 2016, 04:12AM
nzoomed wrote ...
nzoomed wrote ...
You might try these.
