  • Guests: 30
Oscilloscope Choice
first  2 3 4 5
Fri May 08 2015, 09:05AM
I finally got it yesterday, only got to test all 4 channels and play around with the menu's. Planning is ofc so good that I have to travel away for 5 days with work, so the new toy will have to wait.
It seems the USB support is just as bad as from the DS1052e, first it would not recognise my sticks, then it acts up weird when one is inserted, but it does no longer detect it. I finally find one that works, make a folder with the built in disk manager, oh god yes, chinese characters and 2GB files that can no longer be deleted.
Best way to save to USB, the nice green printer button will quick dump, no need to go through menus anymore :)
also riglolled.
1431075951 1403 FT168268 Imag1448
1431075951 1403 FT168268 Ds1z Quickprint1
loneoceans
Fri May 08 2015, 04:10PM
Mads Barnkob wrote ...
also riglolled.
I found that the actual USB stick does matter a bit - some of them would be intermittent and some would work great. I found a quick reformat of the USB disk seems to work. Still, can't beat this for $399. :)
Fri May 08 2015, 04:52PM
loneoceans wrote ...
The 4GB FAT32 stick I had that worked in my ds1052e did not work in the ds1054z. Neither did it help to quick format, normal format and at any given combination of FAT/FAT32 and allocation size that you can do with windows format.
Another 4GB FAT32 stick that never worked in the ds1052e was instantly recognized by the ds1054z. However, when i made a folder using the built in file manager it was full of chinese letters and 2GB files, a folder which the ds1054z itself could not even delete again. Windows asked to repair the stick after that and then the folder was gone.
"Flash drive filesystem init failured"
Electroholic
Thu May 14 2015, 11:55AM
This was what I could afford at the time. Solid scope, had it for 3 years, not a single problem. USB works integration is seamless, will boots from USB if you really want.
1431603872 191 FT168268 Imag0061
Still would like more advance trigger options tho.
first  2 3 4 5
