  • Guests: 53
Work related post: Eliminating static charge
Sat Dec 13 2014, 12:11AM
I imagine it's only the biggest charges taking out the robots. There was some mention of 6" sparks earlier in the thread.
You may not need to discharge everything, just those with the highest charge, Th Christmass decoration should get most of it, certainly those with unusually high charge, and I imagine it also has a fair bit of resistance already.
Thu Dec 18 2014, 02:35AM
Talked to the electrical maintenance supervisor about changing the location of grounding straps and adding more closer to the point where the foil is unwound. He brushed it off in ~3 sentence fragments in favor of a "total static control system" with a 5 figure quote >_<
Thank you all for the input but as always you can't fix dumb.
Shrad
Thu Dec 18 2014, 08:04AM
this is why we can't have nice things...
Fri Dec 19 2014, 03:44AM
No kidding. How long will an ion sprayer last in a plant that accumulates ~5mm/day of dust on all exposed surfaces?
Shrad
Fri Dec 19 2014, 07:56AM
then you'll have nice things, once it'll have arced all over its own guts ;)
besides that, the reason there is so much dust might be electrostatic as well....
BigBad
Sat Dec 20 2014, 05:27PM
If it was me I'd stay behind after work and put up the 'christmas decorations'.
Sun Dec 21 2014, 05:19AM
I'll be bringing some Christmas Garland over the Holliday's to test while middle/upper management is off. If it works I will take it all down, document my results and wait for beurocratic failure to ensue.
