  • Guests: 45
RoV IW3IPD (63)
01/13 si2030 (62)
Work related post: Eliminating static charge
Wed Dec 10 2014, 01:34PM
UV light can be used to eliminate static charge if the charge is negative, but I don't know how practical it would be in this case.
Link2 Link2
Shrad
Wed Dec 10 2014, 02:24PM
in that case (I guess this is insulation material fabrication as described, like rockwool or similar products) the bands seem to act as a giant van de graaf
if you allow a string of garland to pick charge under the belt at some places (so that only the small hairs of the garland are touching the belt) and ground the garland, I think it would suffice
are the belt rolling cylinders in nylon or PTFE, or any other insulating material? if so, maybe use some conductive ones? are the belts themselves well grounded?
did you check for potential difference between the robots and any other large metal frame in the process, which would indicate ground loops or inadequate potential equilibrium?
BigBad
Wed Dec 10 2014, 05:39PM
Sticking the robot controllers in Faraday cages could help.
Thu Dec 11 2014, 12:08AM
All of the rollers used to move the product are metal however there are are a few hundred meters of conveyor belt used in the transport system. All of the conveyors run over grounded frames but I'll check them out for static next shift.
I don't know the polarity of the static charge (hadn't thought of it) but I will grab a neon bulb next time they run it and find out.
The plant is about 400,000m^3 so climate control is unfortunately out. If we could control the air it would be a lot nicer place to work than it is now (5 degrees in the winter and 30 in the summer). We do however have the same static problem even in the summer when there is very high humidity.
I agree that the charge is more than likely on the glue and that this might be like the x-ray scotch tape effect.
Thanks again for all the input. I'll be shopping for garland shortly >_<
Shrad
Thu Dec 11 2014, 08:47AM
Nik wrote ...
do you have the opportunity to test the area with a scintillator or detector of some sort?
I think even an old digital camera would indicate if there is radiation emission... this is worth checking
Fri Dec 12 2014, 01:02AM
To get x-rays the tape had to be unrolled in a pretty serious vacuum, the plant I work in unfortunately operates at around 1 atmosphere >_<
BigBad
Fri Dec 12 2014, 03:29AM
I suppose in this situation the metal backing is your friend. If you can earth that, even if the hot glue on it is charged, the metal backing will create the opposite charge very close by and tend to cancel out the voltage practically everywhere.
So lots and lots of garlands; you want the metal discharged everywhere, and obviously, you don't want the garland to be a short to earth, it should really go through a resistor to slow the discharge to avoid creating a magnetic field/radio wave and EMC issues.
The thing I'm most interested in is the robot manipulator itself, when it picks up the sheet and lays it down, I'm thinking that MUST be earthing the sheet the whole time. If it's not, and it picks up the sheet in any voltage field, then as soon as it moves the sheet, there's electrostatic induction going on right there.
I mean Q=cV, charge is conserved and the capacitance will be varying if the capacitance is reducing then the voltage can go sky-high.
Shrad
Fri Dec 12 2014, 08:05AM
the problem is that before passing on the belt, the metal backing and rock wool are spliced in parts and piled, then are traveling unconnected from any metallic source
maybe BigBad is right and you just have to let a string of garland gently touch the metal backing when it comes out of the coating machine, so that it is discharged before reaching the belt
it would be the same as grounding your van de graaf bottom end
BigBad
Fri Dec 12 2014, 05:35PM
The metal backing needs to be earthed the whole time they are being piled; you do NOT want to be piling up any net charge.
If they have any net charge, as they come together the voltage will be going up, roughly proportionally, with each extra sheet added to the pile.
Shrad
Fri Dec 12 2014, 08:19PM
could it be an idea for a new type of static generator?
