  • Guests: 65
LTX (57)
01/29 IAmSpock (18)
01/30 Ian (37)
01/30 Lucas (40)
Polyphase induction motors
Shrad
Mon Dec 01 2014, 10:44AM
klugesmith wrote ...
Funny that should come up on 4hv, the day after I stumbled on literature about shaft voltages and bearing currents. Their existence had never occurred to me, except for "ball-bearing motor" demonstrations.
Turns out it has become a significant problem with the advent of HF-switching VFD's, and can rapidly damage ball bearings unless mitigated, for example as Shrad mentioned. Link2
maybe it has to do with the frequencies interfering with crystalline structure of different steels...
BigBad
Mon Dec 01 2014, 01:36PM
No, it's just induced currents going through the bearings causing arcing and pitting. The problem pretty much goes away if you insulate carefully.
Shrad
Mon Dec 01 2014, 01:40PM
or use ceramic bearings, but they are not cheap...
