  • Guests: 35
Propeller Physics and VABs Program.
Sun Nov 16 2014, 02:53AM
Andy wrote ...
Ash you missed the point about Link2 to arrive at Link2 , the veolicty is to the power, ether reuqires more power input or generators more thrust shades
Post edited.
Maybe I missed your point.
Looking at this again, the velocity bit is where all the losses originate. The larger the 'disc area', the lower the velocity for the same 'lift'.
I think this is why the 'v to the power' term disappears.
Is this the point you were making?
EDIT: It also states that "the "efficiency" of an otherwise-perfect thruster, is proportional to the area of the cross section of the propelled volume of fluid"
Mon Nov 17 2014, 03:57AM
Sorry about the double post, but new information:
Ok, 102g requires 1N (1kG/9.81) and 1kG requires 9.81N
9.81^3 = 944
944/(4.9x0.5m^2) = 385
square root 385 = 19W
With 1m^2 disc area, power required is 13.9W
With 2m^2 disc area power required is (Curiously) 9.81W
These figures don't take into account any other losses in the system, but they do demonstrate the point. They are all based on total 'copter mass of 1kg, with a single rotor.
So, in this case, quadrupling the disc area halves the power required, which doubles the flight time.
31.5 inch dia rotor gives 0.5m^2 disc area
and 63 inch diameter rotor gives 2m^2 disc area
We just need to calculate for some more realistic figures.
Mon Nov 17 2014, 10:03PM
I cant figure out how to use this software,(SU^2) its a .tgz , which i un-compressed, but i dont know which file to use?
there appears to be know .exe , so do i have to compile this ? sad
And...
Shrad
Tue Nov 18 2014, 08:18AM
linux program which is to be compiled ;)
Tue Nov 18 2014, 08:38AM
So how do I compile the windows version? is it 32 or 64 bits ?
Wed Nov 26 2014, 03:55AM
Link2 im wondering how to use these, or how to choose one.
i may just use this one. Link2
i cant get this to work on my computer : Link2 its got all kinds of instructions and possibilities scattered on his pages. i just need one java method that will work.
EDIT: i may have it working...
1416986284 2431 FT1630 Flow1
im not sure what the Vx and Vt numbers mean, but the graph and gradient are amazing.
Shrad
Wed Nov 26 2014, 08:15AM
glad you have sorted this out,
if you have to use a linux program you can always create a virtual machine and install a small linux distribution like debian
it's a project on its own but you can repurpose it as a scientific computation machine by installing python and scipy
along with some µC able to run python and communicate with a host PC in python, this could prove as useful as a labview setup
Wed Nov 26 2014, 10:26AM
im thinking of buying one of these 18 inch props Link2 then utting it in pieces. one piece form the tip and so on to the hub. while measuring the critical dimensions. however scaling with fluids always worries me. but going from a 18 to a 26 incher wouldnt be as sketchy as scaling from 10 to 26.
its tempting to make a mold using my 3D printer, and lay up props out of CF. those 26 - 29 inch props are just to expensive to be putting into a tree.
Wed Nov 26 2014, 03:58PM
The other option would be to put a series of 'theoretical' dimensions into a 3D CAD package, and then produce a 'net'. From this you could program a 3D printer to produce a mold.
Wed Nov 26 2014, 09:24PM
Ash Small wrote ...
i dont get this... elaborate please.
