  • Guests: 66
01/04 bomberguy92 (34)
01/05 Timo (40)
01/06 Ash Small (63)
Light LED with 4 nanoamps
Zamboni
Wed Apr 22 2015, 02:12AM
Zamboni Registered Member #2836 Joined: Fri Apr 30 2010, 01:24PM
Newton Brawn wrote ...
Hi Zamboni,
If you set the moving pendulum in a " neutral " position, the pendulum can start the oscillation movement by it self ?
Yes. If stopped in the "middle" of the cycle, the Swinger will be attracted to one pole and start the cycle.
Paul
Tony Matt
Wed Apr 22 2015, 03:02AM
Hi Zamboni,
In this project I think the best approach shall be separate the pendulum device from the light flash. Once we " dominate " and solve the flashing light issues them we may return our attention to the pendulum and integrate both into devices the battery.
Answering your questions:
1- Yes the spark gap is the best switch for discharge 500V from the cap / battery into the coil and diode. Note that the cap is connected in parallel with the battery all time.
2 - I try to understand your schematic and I am not sure it works. I will try post the schema showing what could work.
The diode could be a 1N4007, as tested and approved by Antonio's video. Two 1n4007 connected in series can handle 700V or more. during the switching the diode may comutate 2-10mA or more (for very short time).
Tony Matt
Wed Apr 22 2015, 04:39AM
Here the schema more readable...
1429677581 3700 FT163929 Zamboni 2
Zamboni
Wed Apr 22 2015, 12:53PM
Antonio wrote ...
I dont't think that the idea can work in this way. But your schematic shows something that was forgotten in the previous discussions. The swinging pendulum is not short-circuiting the battery, but just taking a small charge from one terminal of the battery and, after swinging, returning the charge to the other and taking a small opposite charge. A possible solution is then to increase the charge that goes to the pendulum by adding a capacitor connected to it (by a thin wire that can be its support), and make the charge pass through a "floating buck converter", as in the picture. Another capacitor is connected across the battery, that has the negative terminal grounded. The LED will flash when the pendulum touches the positive terminal.
1429663987 834 FT163929 Swing
Antonio,
Your idea is quite intriguing. The only problem is that in my Device, nothing can touch the Swinger. The Swinger is held under a sapphire V jewel by a magnet. Any additional friction will stop it dead. I had thought about holding the needle directly on the magnet, but, because the Device rotates about 14 million times a year, the needle will "drill" into the magnet very quickly and cause the Device to stop. I had to add a sapphire bearing to reduce the friction enough to keep it going.
Thank you for you ideas. Matt has used your calculations in his circuit.
Paul
Zamboni
Wed Apr 22 2015, 12:57PM
Tony Matt wrote ...
Tony,
I will round up the parts and see if I can get it to work without the Device. I will let you know as soon as I get it built.
Paul
Zamboni
Thu Apr 23 2015, 09:06PM
Tony Matt wrote ...
The idea to “dominate” the method, and then try to get it working on my Device is a good idea. To that end, I connected a 3.3NF 2Kv capacitor to both the battery and my “Plexiglas and screw” spark Gap. The small neon bulb was connected through the spark gap.
The thought was that the battery would fill the capacitor, and then the capacitor would discharge through the spark gap into the neon bulb.
I figured that I would add the additional circuitry, once I verified that the concept was sound.
It worked. About every minute, I got a very visible flash of light. I, foolishly, used one of my “good” batteries (1700 volts) to test the theory. Turns out that even though the theory worked like a charm, the patient died.
I will explain, using my less than perfect knowledge of these batteries. As noted by another member, my dry pile batteries have about a 300 Giga-ohm internal resistance. The 3.3 NF capacitor has a substantially lower (though still very high) resistance. The end result was that, from the batteries point of view, the capacitor is a direct short. These batteries are extremely sensitive to direct shorts. I only had the battery connected for about 30 minutes. During that time, my 1700 volt battery Device drained down to a 1500 volt Device. Bummer…
I should have thought of this, I am painfully well aware of the sensitivity to “short circuiting” the battery.
I have researched “Glass capacitors”, that have 100 Giga-ohm resistance, but even they would appear as a short circuit. My conclusion is that I can’t ever have a capacitor directly hooked to the battery.
Has anyone ever of a capacitor that has greater than 400 Giga-Ohms of resistance? It would be nice to have a Tera-ohm of resistance.
The idea of using the “transferred” 4 Nano-amp charge that the Swinger moves from terminal to terminal is still viable as a concept.
That concept requires a way of keeping the transferred charge in the capacitor. The negative terminal must remain at or very near zero. I am guessing that the leakage back through the diode would be large.
Without about a Tera-ohm of resistance, there can be no direct connection to the battery. Direct hook up to the battery will cause failure…quickly.
The only thing that I can safely connect to the battery, is an Electrostatic voltmeter. The one that I have has a 1 X 10^15 internal resistance. I have left batteries hooked to the meter for weeks, with no damage whatsoever.
I have enclosed pictures of the Electrostatic voltmeter, the setup that I used and the spark gap that I made.
Paul
1429823189 2836 FT163929 Paulsetup
Andy
Thu Apr 23 2015, 09:31PM
Hi Zamboni
Can you recharge or remove salt production, by running for a short time ac voltage source throught it, not 100% sure it will need a high ac source thought?Maybe have two piles, when one fires the otherone fires reverse porilty into the tempary low first pile as a ac source, and vice verser.
You could try instead of paper, titanium dioxide or caliucium copper titanate, so the pile capance matchs closer to the cap your trying to charge.
Zamboni
Thu Apr 23 2015, 11:25PM
mister_rf wrote ...
Nice work. May I suggest you to use some high-efficiency LEDs for your experiments?
I have built a test circuit, controllable current source, connected to some various high efficient LEDs and cranked the dial down to observe the minimum threshold I could see the LEDs light.
It was as low as 10 nanoamps recorded by the camera, but in practice, in a complete dark room the light is quite visible with the naked eye down to 5 nanoamps.
I have been home-testing the following LEDs:
WURTH ELEKTRONIK 151053GS03000 green, 10.000 mcd, 522nm
KINGBRIGHT L-2523QBC-D X-BRIGHT blue, 2.300 mcd , 465nm
AVAGO TECHNOLOGIES HLMP-EG1A-Z10DD red 21.000 mcd 630nm
OPTOSUPPLY OSW54L5111P white 75.000 mcd
CREE C503B-RAN-CY0B0AA1 red 23.500 mcd, 630nm
The LED's arrived today. I hooked them up and they work the same as the other LED's. There was no discernible difference.
Still far too dim.
Good idea though.
Paul
Zamboni
Thu Apr 23 2015, 11:31PM
Andy wrote ...
Hi Zamboni
I actually tried Titanium dioxide several years back, the output was lower than what I am using now.
It may be possible to recharge them, but I think I will cut my losses and be happy with 1500 volts.
Paul
Antonio
Thu Apr 23 2015, 11:39PM
Normal commercial capacitors really don't have a very high parallel resistance, specially due to surface leakage. When I use them in experiments the first thing to do is to clean their exterior carefully, apply some wax, and dry everything with a hair dryer. You can make a Leyden jar capacitor using a HDPE plastic pot, that has very low leakage. Can these batteries can be recharged?
