  • Guests: 89
RoV IW3IPD (63)
01/12 RoV IW3IPD (63)
Driving X-Ray tube with ignition coil.
first  2 3 4 5
zippotix
Sun Nov 16 2014, 09:31AM
zippotix Registered Member #5208 Joined: Thu Jun 07 2012, 06:12PM
Thx Ash, this worked better than capacitor. Still, tube emits X-rays, but they won't light up the screen. I think they are of sufficient energy, but there is simply not enough of them. HV regulates the energy in keV, and filament regulates the flux?
zippotix
Tue Nov 18 2014, 02:15PM
I have an idea; I will place a voltage doubler between dimmer and iggy coil. Would this increase the output voltage? Or would this interfere with chopped up sine wave of the dimmer (triac)?
zippotix
Tue Dec 30 2014, 08:17PM
Today I finally got proper, clear radiographs, with about 90kv from dual ignition coil and 50uF capacitor, 2C2S (similar to 2X2A). I'd be happy if not the fact that while I was searching for some target relay failed and it started to emit x rays. I don't know for how long it worked before I noticed but certainly more than one minute. What can I expect? I'm kind of worried...
Sigurthr
Tue Dec 30 2014, 11:16PM
Depends on tube current, proximity, directionality, etc.
Skin burns are characteristic of low energy X-ray exposure at high dose rates.
A white blood cell count can help determine if bone marrow damage has occured.
Chances are you're probably ok if you don't get ill or see any skin effects.
zippotix
Wed Dec 31 2014, 11:15AM
I have no way to determine tube current, but I think it's about 5-10mA, it's a rough estimate. Distance was more or less 50cm. I guess the dose received was not more than 50mSv, and interwebs say leukemia risk increases above 100mSv but still, this was not particularly healthy.
zippotix
Thu Jan 01 2015, 05:49PM
Anyone has any idea what would be 2c2s radiation output at 90kvac? I searched the interwebs but couldn't find anything.
johnf
Thu Jan 01 2015, 08:37PM
X-ray tubes typically output 0.1 of 0.1% of x-rays vs current
so 1mA (=1.6 x 10^16)gives 1.6 x 10 ^12 x-rays per /sec or about 1.6 tera bequerel
zippotix
Thu Jan 01 2015, 08:38PM
That's what it looked like suprised
1420144739 5208 FT162974 10893893 1584696525099116 2123179677 N
zippotix
Thu Jan 01 2015, 08:56PM
Johnf, so what would be effective dose? I know something about activity, but 1.6 TBq is really big number so I don't know what to make of it
Wed Feb 25 2015, 05:43AM
Yeah, reducing the current with a 1 G ohm series resistor would be the first thing I'd try.
5642s are pretty sensitive to overcurrent and a tube which worked perfectly well with pulsed power failed within seconds in continuous mode.
first  2 3 4 5
