  • Guests: 80
IGBT input capacitance
Antonio
Sat May 03 2014, 03:15PM Print
I obtained some FGH60N60SMD IGBTs to use in a DRSSTC driver and was testing them. They appear to work (in low voltage at least), but I found strange the input capacitance measured with a capacitance meter between gate and emitter. By the datasheet I should see a bit more than 2 nF, but in most of by devices I am reading about 8 nF, and in others I measure just 1 nF. I know that the capacitance is nonlinear and the meter may be inventing something, but I was expecting something more consistent with the datasheet. Could someone with these devices at hand verify?
Artlav
Sat May 03 2014, 10:30PM
Artlav Registered Member #8120 Joined: Thu Nov 15 2012, 06:06PM
Just tried 4 of them, date code (line above the name?) is 1C32AH.
4.4 to 4.6 nF with a multimeter, 4.0 to 4.2 nF with an LCR meter (any frequency).
Don't have ones from another batch.
I thought that the gate have a specific amount of charge, not capacitance, so C will be very voltage dependent?
However, it does not add up anyway.
Antonio
Sun May 04 2014, 01:07AM
The capacitances depend on the applied voltages (probably incremental capacitances), so what a meter will read depends on how it measures the capacitance. What I find strange is the large variation in the ten that I have, with cies (between gate and emmiter and collector short-circuited) between 1.59 nF and 9.72 nF, with half of them above 8.36 nF and the others below 6.20 nF. The curves are from the datasheet.
1399165555 834 FT162890 Capacitances
Uspring
Tue May 06 2014, 09:39AM
I just measured my only left over IXGN60N60C2D1. It has 5.8nF with open CE, which is close to the datasheet value.
Tue May 06 2014, 10:09AM
Antonio, where did you get your IGBTs? Is it possible they might be counterfeit parts? Can you post some high resolution pictures of the packages and markings? (put them in a flatbed scanner)
Antonio
Thu May 08 2014, 01:03AM
I bought them from a chinese site, for a suspiciously low price confused
I didn't test them at power yet. They behave as should at low power, but may be really counterfeit.
1399510940 834 FT162890 Igbt
Thu May 08 2014, 06:27AM
According to fairchild the marking is coded as follow:
Line 1:$Y (Fairchild logo) &Z (Plant Code) &3 (3-Digit Date Code) &K
Line 2:FGH60N60
Line 3:SMD
So according to: Link2
We have the Fairchild logo, looks okay.
B is the plant code for Bangkok, Thailand (Subcontractor)
The next 6 digits have me puzzled. It should be 5 as its "3-Digit Date code format" and "2-Digits Lot Run Traceability Code"
but...
"When marking info does not have &K or &T, the following trace code assignment logic will apply.
When date code type is "S1" or "S2" - Lot Code will be assigned as Trace Code."
Since its given to be a S1 marking, there might be something else and I am not too sure what the trace code is.
But atleast the surface does not look like it was milled down, so maybe they bought packages without text on to start with and did a little crude laser job.
Some other F markings seems to just be a thin line all around.
Antonio
Sun May 18 2014, 10:52PM
An update: I tested a pair in a small drsstc with a half-bridge driver. They worked perfectly, switching up to 100 A without even getting warm. I see, however, a lot of noise in the primary current at each switching, what I was not seing with mosfets in a similar driver. Maybe just because the switching is faster, even at 300 kHz. Investigating.
Tue May 20 2014, 08:08AM
Figure 9 in this data sheet should answer your original question: Link2
Antonio
Wed May 21 2014, 12:43AM
Dr. Dark Current wrote ...
I posted this curve above. The capacitances are nonlinear, and so the value read in a capacitance meter depends on how the meter works. I am using two that read around 3 nF. The others I will use in a driver with several in parallel, but this requires a redesign of everything that I have, starting with the secondary coil that is too lossy.
