  • Guests: 54
Inducktion (32)
Standa (31)
nabzim (33)
12/23 David (39)
12/25 Kolas (18)
Novel flying machines
Wed Jun 11 2014, 12:12AM
so what should a duct look like then Uspring? should it follow the pressure drop driven by the veolcity?
Wed Jun 11 2014, 01:40AM
Udo provided the maths here, Patrick. I can't do that. All I can do is provide the basic theory. As I said in an earlier thread, my experience is with marirne propellers. I've learn't a lot this evening, thanks to Udo.
Wed Jun 11 2014, 05:38AM
i have really important data captured. but i need to put it into excel or a table. but theres some important results revealed.
first below 4krpm these props are ultra low on thrust, but at 5krpm and above they really pick up fast.
second as would be expected, most of the thrust comes from the outer sector of the radius swept.
third, the electric "E" 11x5.5 prop meant for fixed wing flight generates:
6.5g/W at 5,100 rpm (458g, 71W)
5.7g/W at 6,100 rpm (646g, 114W)
4.9g/W at 7,050 rpm (884g, 179W) (<- at 16.1 Amps and 140F, this is getting close to the max.)
which is important, now i can choose the operating point for the hover more for the grams per Watt value than just hope and guess. It does occur to me that at minimum thrust the efficiency is high, so many small props and motors would be advantageous, i guess we've talked that out before too.
so a 3-blade prop should generate more thrust from a given diameter.
1402466960 2431 FT1630 Maxresdefault
2b
The above wide fan induction blades intrest me, is there any practical way to get higher g/W values with out the diameter getting bigger and bigger? After 10" in diameter ducts get hard to support, there prone to wobble and flutter.
3 and 5 blades per prop may be needed if its the outer circumference where the effciency and force are trying to hide from me.
Uspring
Wed Jun 11 2014, 09:21AM
I was thinking of something like this: Link2
The duct should have a snug fit around the prop since there is a pressure jump from right before to behind the prop. Your thrust stand should be useful for some research.
Edit:The numbers you measured agree quite nicely with the equation
F = eff * (2 * rho * A * P^2)^(1/3)
F = thrust, rho = 1.225kg/m^3 (air density), A = prop area, P = motor power.
eff is the props efficiency, which turns out to be about 0.5 for your measurement.
Wed Jun 11 2014, 12:55PM
FWIW, 50%-55% efficiency is about the best that super-cavitating, surface piercing props on offshore racing powerboats can achieve, although some large, slow turning props on ships can reach around 80% efficiency, if I remember correctly. It's a while since I was involved in this stuff. It's good to see you're making some progress, Patrick.
Patrick wrote ...
Several small props close together (as in my heptacopter design) should approximate to one large prop, and the efficiency should rise further (meaning you can carry more batteries), although this is unproven theory, as yet, anyway.
BigBad
Wed Jun 11 2014, 05:07PM
Uspring wrote ...
The physics for drag and propellers are similar. Both are based on acceleration of air masses.
More precisely, as the propeller (or any body) moves through the air, it deflects the air, and also creates drag on the air.
Both go, to a first approximation, as v^2 (where v is the speed of the rotor through the air, not the down-wash speed), and the two are related by the L/D ratio:
Wed Jun 11 2014, 06:28PM
Uspring wrote ...
it really looks like a tube around a prop or turbine, but those are heavy as i said, and difficult to attach. I was told by Embry-Riddel students to keep the the gap at 0.010 or so from tip the duct. but thats awful hard, in my first attempt you could hear the prop chattering the whole time.
in that pic are they using an electric turbine, Uspring? we cant really see the face.
if i could go from 0.5 to 0.7 eff id freak ouuut.... and consider this whole thing a sucess. im also wondering if i should mod the stator to carry more copper for the same number of turns.
Wed Jun 11 2014, 11:00PM
i think, but I'm not certain, that 'turbine' style 'fans' are only really of benefit for higher pressures, which is not really what is wanted here.
Maybe someone else can comment?
Wed Jun 11 2014, 11:28PM
I'm wondering what effect pitch has, Does it capture more air mass for example...
BigBad
Thu Jun 12 2014, 12:07AM
yup, progressively increasing the pitch gives ever more thrust, right up to the point you stall the blades out.
of course, it's less efficient; the most efficient is quite a small pitch
