  • Guests: 21
David (39)
12/25 Kolas (18)
12/26 buxtronix (50)
Recieving GPS In High Radiation Fields... (Among Other Unfavorable Situations.)
Tue Apr 15 2014, 11:00PM
I think the GPS is the least significant problem, the greater problem is the computing of flight and operational commands. Besides it's looking like I need to switch between inertial nav and radio fixed beacon triangulation at fukushima/Chernobyle/Windscale/hanford sites.
BigBad
Wed Apr 16 2014, 12:47AM
Patrick wrote ...
BigBad wrote ...
Radiation shielding is a git. It's one of a few areas where there's little substitute for throwing mass at something.
0.125 inch/3mm thickness of lead probably would not do a lot; you'd need more like several inches.
for a flying machine, 3mm of lead is all i can afford. the purpose of adding it selectively, was to reduce the probability of simultaneous-similar failures in the parrallel compare logic and MCU.
does that sound credible or useful?
im researcing boron carbide as well... 2.5 vs 11.3 g/cm^-3
It will help with some types of radiation.
Basically, there's alpha, beta and gamma.
Alpha and beta you might well be able to shield.
Gammas will just go straight through.
You've also got to watch out for secondary radiation; when you stop primary radiation, it creates a shower of secondary.
Basically, it's very complicated; and there's much less scope for shielding flying machines.
You might even be better off with very little shielding due to the lack of secondary radiation and just rad-harden everything.
Wed Apr 16 2014, 02:00AM
Of this is a point of future research, clearly more in depth then I first realized... but please continue to comment everybody...
Carbon_Rod
Wed Apr 16 2014, 07:08AM
Most of the solutions to these problems have been documented for aerospace projects. We've seen consumer grade AVR processors in research satellites function just fine. However, I'd suggest looking at a 1990s version of an old Motorola 68HC (1st gen) or intel 32 486sx series based computer.
Note, that export of any hardened control system is now prohibited if the device is intended for an Unmanned Aerial Vehicle... even if for civilian applications.
Even the hardened fault-tolerant software developed by NASA would fall into this class.
wink
Wed Apr 16 2014, 07:59AM
As I see it, your key systems are;
1) Onboard flight control
2) Uplink receiver for flight commands
3) GPS receiver
4) GPS decoder
5) Onboard instrumentation e.g. Radiation measurement
6) Onboard video camera(s)
7) Downlink transmitter(s)
8) Ground based equipment
Item 8 should of course be in a low hazard area
Item 7 should be less susceptible to radiation than other key systems
Item 6, the live video downlink will show video noise
when radiation levels are high enough to cause electronic failures
.. early warning if no onboard radiation monitoring.
Item 5 is designed to work in a radiation environment
item 4 can be eliminated by directly sending the GPS receiver data to the ground station for decoding.
Item 3 could temporarily/intermittently fail
but the ground station decoder should be able to quickly re-synch,
especially if assisted gps is used at the ground station
Items 2 and 1 seem to be the most critical,
flight command receiver interference can be mitigated by the flight controller only accepting valid commands,
e.g. sending a digital data stream with error detection/correction.
I've no idea how item 1, the flight controller, can be 'protected'
Physical shielding of the core controller may be assisted by strategic location of batteries and less critical parts.
One minor thing, can radiation cause a LiPo failure .. catastrophic.
If the vehicle is small/light (not likely to harm the target site)
then it may prove cheaper to provide moderate protection
and accept the occasional lost vehicle,
and have multiple 'expendable' vehicles
as the relative cost of vehicles to project costs is negligible.
Wed Apr 16 2014, 09:58AM
Patrick wrote ...
Proud Mary wrote ...
Sorry that I haven't been around so much lately, but I have quite a lot on my plate at the moment.
no prob, but im still wondering how they built the Cassini and Hubble spacecraft.
NASA: Commercial Off The Shelf (COTS): Radiation Effects Considerations and Approaches
How Rad Hard Do You Need? The Changing Approach To Space Parts Selection?
Radiation Hardening at the System Level Link2
BigBad
Wed Apr 16 2014, 08:00PM
Patrick wrote ...
You should read this:
So gamma and neutron radiation is the most problematic; you can practically shield alpha and beta
Sat Apr 26 2014, 03:02AM
So, would neutron emitters be present, or neutrons fast or slow be escaping from a reactor in the condition of those a fukushima? After all they aren't fully opened up as in Chernobyl...
Sat Apr 26 2014, 07:00AM
Patrick wrote ...
"By March 23, 2011, neutron beams had already been observed 13 times at the crippled Fukushima nuclear power plant." Link2
There are plenty of other articles regarding these 13 'observed' neutron beams on the internet.
