  • Guests: 135
muller (38)
Dr. Mario (38)
Ben Solon (30)
01/28 LTX (57)
01/29 IAmSpock (18)
01/30 Ian (37)
Antenna cyclotron
Andy
Wed Jan 22 2014, 05:56PM
I have 12volt between 14,7, the voltage of the hex max is 15volt.
2 = 11.3dc
12 = 9.53dc,32-0.2ac
10 = 12.13dc,39-0.2ac
8 = 10.48dc,31-0.2ac
Mosfet 9.63dc at gate, ac 32-02
I'm using a 500khz resonator, I'm not sure weather its designed for it.
The multimeter as a hz functions, but it stays at 50hz.
Yep, cheers
Wed Jan 22 2014, 07:01PM
74LS04 is a 5V Vcc device with absolute max 7V, so I expect it has packed up.
Andy
Wed Jan 22 2014, 07:05PM
Says it is rated for 15volt , sorry that diagram was just to explain what the circuit was meant to look like, my bad. Link2
Andy
Sat Jan 25 2014, 11:41AM
Hi, was wondering what amount of current would need to be supplied to a 100nF cap at 150-300kv, and if its possible at 500khz, or would a lower hertz be better?
Cheers
Andy
Sun Jan 26 2014, 08:58PM
Hi, I would like to run the below setup, but I'm worryed that the NST will find a way onto the house ground from the top power source, is there anyway to stop that, the only option I can think of is a 1.5kw battery inverter to power the thing with it placed on a plastic box.
Should I maybe remove the NST ground connection, would that help.
1390769703 4266 FT1630 Scale
Cheers
