  • Guests: 28
Wizzup (30)
12/09 Killa-X (34)
12/09 Luca (45)
12/10 davovinch (75)
Taking a MOT out of saturation
StormInABottle
Wed Dec 11 2013, 08:02PM Print
I have around 225 - 240 volts. Would removing the shunts and adding 60 turns of 12 guage wire to the primary take the MOT out of saturation. Do note that it is fairly powerful (Came out of a 3KW oven)
Dr. Slack
Wed Dec 11 2013, 09:05PM
Removing the shunts will do nothing for saturation, however it's needed to give you the space for the extra primary turns. If these extra turns are connected in the correct phase, then that will take you out of saturation.
Unless ... you have a 120v MOT. What is the mains voltage for oven MOTs on Andromeda?
StormInABottle
Thu Dec 12 2013, 05:34AM
240 volt mots. How can I make sure they are connected in the right phase? I bet the mot will be much more efficient.
MrFlatox
Thu Dec 12 2013, 08:06AM
MrFlatox Registered Member #9349 Joined: Mon Jan 07 2013, 08:50AM
Hi !
I experimented with that, but i went to another way. It was mainly for a low voltage application :
I removed two mots secondary, then i disassembled two mots and kept the two E cores, then i welded them together. That way, i had two mots primary for the same iron area, and plenty of room for wiring a new low voltage secondary. I wired the two primaries in series so that each of them would only see half of my 240v line. In other words, the new transformer had double primary turn per volt ratio.
As a result, the transformer was out of saturation, and could run 24/24 without overheating the primary. The magnetizing current was also pretty low.
Dr. Slack
Thu Dec 12 2013, 09:59AM
StormInABottle wrote ...
If you have a suitable source of low voltage AC, then energise any of the windings, and measure the voltage across your new composite primary. Reverse the phase of the additional winding and measure again. Choose the phasing that gives the highest voltage.
If you don't have a low voltage AC source, then just energise the original primary from the mains. Measure the result carefully because you are now on the mains side! Don't experimentally energise the new composite primary first off as, if the phasing is wrong, you may take out fuses or breakers.
StormInABottle
Thu Dec 12 2013, 10:12AM
Will a 36 volt 20 amp transformer do?
Dr. Slack
Thu Dec 12 2013, 03:16PM
On the one hand, yes, 36v would be excellent for testing.
On the other hand, if you have to ask that question, I'm now not so sure about aiding and abetting you to muck about with transformers? Take care!
StormInABottle
Thu Dec 12 2013, 04:47PM
I just like to take opinions. Hehe
GeordieBoy
Sun Dec 15 2013, 08:38PM
If you have a generator available you can also reduce the volt-second product by increasing the frequency. That will have a similar "saturation reducing" effect as adding more turns to the primary or reducing the primary drive voltage, but without reducing the HV output from the secondary.
Newton Brawn
Mon Mar 03 2014, 02:52PM
I am in fully agreement with Dr Slack. Follow his recommendations.
When I need to phase a MOT primaries I use to apply 230V on the secondary.
Then I measure voltage at the normal factory primary and the voltage at the new primary coil.
Normally I get the following primary voltages:
Normal Factory Primary Coil= 24V
New Primary Coil (60 turns) = 6V
When connecting the primaries in series I can get the following voltages:
a - 18V (this connetion will saturate MORE YET the core) - avoid it.
b - 30V, (this connection will reduce the core "saturation" ) - use this connectiion.
One lead of the secondary coil is factory connected to the core, so whem applying 230 or 110 V to the secondary the core will be enegized with the line voltage. Be carefull toching the core, the core is hot with 120 or 230 volts.
Gauge #12 for the new primary coil will works fine, but appears to be litle oversize - what is the factory primary gauge ? Copper or Aluminum ?? The new primary coil may follow the same gauge (or less) that the factory coil.
What is the purpose for such MOT ??? Give us more information
