  • Guests: 56
Anyone have experience with one of these?
redruM69
Sat Nov 30 2013, 05:40AM Print
redruM69 Registered Member #31557 Joined: Tue Aug 06 2013, 02:38AM
I have 2 of them. Was going to sell on eBay, but decided I may want to keep them if they perform well.
I've heard potential transformers are the next best thing to a pole pig.
I ballasted one to about 125v@7A. Pulled a couple of very hot arcs!
Anybody use these things in TC duty?
4g60 57
1385790017 31557 FT0 T2ec16nw0e9sznmn7bsdct5s6q60 57
StormInABottle
Sat Nov 30 2013, 09:19AM
I've never had experiences with potential transformers but. If each is 4KV. Then they would work really well in SGTC duty.
I would say you would get better sparks than this Link2
I would recommend making a variable ballast. Link2
Sat Nov 30 2013, 01:29PM
These transformers are almost indestructible, compared eg. to NSTs, as they are designed to withstand lightning strikes to the transmission lines etc. and all the rubbish that may appear on the HV lines.
GreenLab
Sat Nov 30 2013, 11:35PM
GreenLab Registered Member #3047 Joined: Thu Jul 29 2010, 10:56PM
PT's are perfect! However, 4kv is very low.
You could switch two pieces in series. 8kv would be enough for a tesla coil.
You can overload pt's slightly with more voltage...
Greets, GreenLab
redruM69
Sun Dec 01 2013, 12:45AM
GreenLab wrote ...
Greets, GreenLab
For a static gap, yea its a bit low. My current ARSG coil is only 4400v from dual MOTs, and it performs amazingly well. I get about 5.5ft hot streamers from a 5.25" coil.
Correct me if I'm wrong, but I was under the impression that since this is an instrument transformer, 4000/100v is just the ratio, not its max capability. I should be able to go WELL over 100v without issues.
Sun Dec 01 2013, 04:50PM
Yes. The saturation voltage of these transformer is about double the working voltage, so you should be able to get 8 kV from one.
Sun Dec 01 2013, 11:56PM
You could use it for a very small mini Tesla Coil using a static gap. These were really popular around 2002-2004 when Gary Laus hosted the mini-Tesla Coil contest on the web where you had to use a 4kV NST limited to about 38mA output current.
Other than that, not very useful.
redruM69
Mon Dec 02 2013, 01:36AM
EasternVoltageResearch wrote ...
Can you elaborate?
I seem to hear this theory a lot. Supposedly lower voltage, high current transformers don't do well with Tesla coils. However, my own, and other MOT coils out there disprove this. I get excellent and reliable performance from 2.5-4.4kv. I honestly believe its a misconception that continues to get spread around.
I understand with a static gap its difficult to get the gap to fire well at these lower voltages, but its still VERY useful with rotary gaps.
In fact my dual MOT setup vastly outperformed the 12kv @ 120ma NSTs I tried using before.
Mon Dec 02 2013, 06:12PM
You can get around 16 kV from 2 of them. The thermal rating is 400 VA per transformer, but if you overvolt them like this, from my experience they will easily take 3x the rated VA (unless you run them for half a day), so that might be around 2400 VA from two.
redruM69
Tue Dec 03 2013, 05:22AM
Dr. Dark Current wrote ...
Hmm.. I was hoping for more power than that. My MOTs are about the same.
