  • Guests: 30
12/06 Dago (37)
12/06 Z28Fistergod (39)
12/06 JonIverson (45)
Gate drive signal
Sat Oct 26 2013, 12:26PM
Hi Furnace, thanks for your PM, which I do my best to answer here.
I'm no expert in these things, but if that is indeed the signal measured off your gate, then we must ask what it is, and where is it coming from?
What is the frequency of that strong sine wave? Is it at your mains frequency - 50 Hz or 60 Hz - or a multiple of it?
If you look at the tops and bottoms of the rough square wave, you'll see it isn't flat, but takes the form of a train of damped waves. You should count the number of peaks on these waves, and work out their frequency. Where are they coming from? Some kind of 'ringing' perhaps?
Sat Oct 26 2013, 02:52PM
If you want to eliminate the power supply as a possible cause, try running it from a car or motorcycle battery.
furnace
Sun Oct 27 2013, 09:01PM
furnace Registered Member #4992 Joined: Wed May 23 2012, 03:57PM
Thanks for the help guys.Proud mary the wave signals you see is measured with the scope at the negateive of the igbt or the inverter and at the one end of the tank. Im running at 40khtz phase shifted. At the moment i cant do any testing because i killed one off my tc chips, so i had to order new stock from digi key which will only arrive on tuesday. I will definitly try the batery ash small to see if the problem can be eliminated this way because i also think that it can be a ripple in my dc regulated supply.
Ben Solon
Sun Oct 27 2013, 10:49PM
It looks to me like parasitic oscillation between leakage inductance and the gate capacitance of your bricks. It looks a lot slower than most of what you see normally, probably because you don't usually see this occur with igbts that large. Could you post a picture showing the igbt bricks and their connection to the GDT?
Mon Oct 28 2013, 12:48AM
furnace wrote ...
Personally I think Ben is on the right track. I just suggested using a battery so that you can eliminate the power supply as the source.
You need to eliminate as many possible causes as possible first, before you start speculating, etc. But trying a battery will eliminate the power supply (I expect), then we can look elsewhere. Also, you need to be certain your power supply is ok.
furnace
Mon Oct 28 2013, 12:55AM
The oscillation is already there before the gdt is connected to the brick so it starts from my 2 tc chips and
it just gets worse when i start giving power to the inverter.
00
Mon Oct 28 2013, 01:04AM
Poor layout and long straggling wires is very often what is behind circuit instability and unwanted oscillation.
furnace
Mon Oct 28 2013, 01:18AM
I did have it with very short wiring but it does not make a difference.As i said the problem is there before the gdt is even connected.
Ben Solon
Mon Oct 28 2013, 01:21AM
furnace wrote ...
00
Is the ringing there before you connect the primary of the GDT to the tc drivers? If the tc gate drive ic's have a clean wave on them when left floating, but then get sloppy when the GDT is connected(bricks connected or not) then you have to look into primary side ringing. could you show the connection from the ic to the gdt? What do you use for the value of your dc blocking capacitor?
furnace
Mon Oct 28 2013, 01:50AM
Yes its already there before the primary of the gdt is connected and i have 1uf cap connected on the primary.So when the tc chips float the signal is not clean. It starts there already.
