  • Guests: 61
Ian (37)
Lucas (40)
01/30 Ian (37)
01/30 Lucas (40)
01/31 Mathias (42)
Electric Motor Effciency (Density / Watt / Losses)
first  7 8 9 10
Mon Dec 09 2013, 07:37AM
BigBad wrote ...
Off hand, I would think that to a first approximation none, since L/D ratio doesn't vary much over that speed range.
Or if it is significant, you've not matched the rotor properly, the L/D curve should be flat near to the hover speed.
well, im wondering how to systemattically verify just this point. i guess running a prop at constant rpm, then measure lift,then keep a 2 element list as rpm increases. power in, rpm, lift out. or what else?
im also wondering if i should consider a variable pitch prop, constant rpm motor arrangement. like a helicopter.
first  7 8 9 10
