  • Guests: 31
Sulaiman (71)
teslarevolution (29)
AromaZ (69)
12/06 Dago (37)
12/06 Z28Fistergod (39)
12/06 JonIverson (45)
Stepping down 200kv to 1kv
first  6 7 8 9
Andy
Fri Sept 06 2013, 08:08PM
Hi Ash Small
Would Nickel work, it is close to Ferrite M33, with properties of 600k and 7.54E-04H/m
Eleccentric
Fri Sept 06 2013, 11:01PM
Eleccentric Registered Member #33460 Joined: Tue Aug 27 2013, 06:23PM
The question to be answered in this thread seems muddled, so I'll focus on the part that I think I can illuminate.
Andy seems to be talking about a very high power influence machine - such as a multi-disc Wimshurst, which would provide the 200kVDC, though the current would be much less than 1 amp. Such a machine (of any reasonable size) might give 200 microamps per pair of discs under normal circumstances, and if built to tight tolerances and operated under high pressure insulating gas can give very high efficiency. The current output is directly related to how fast moving parts of the generator are moving, so making room for theoretical results I'd be willing to consider a figure of 1mA per disc pair. Given a minimum width between disc pair centers of, say, 2cm, this machine would still be 20 meters long not counting the pressure vessel and insulating feedthroughs.
Given that such a thing is possible, would it also be possible to use a sort of reverse-Marx generator? I know the overall efficiency would be destroyed, but as it's an idea I've kicked around a bit previously this seems a good time to suggest it. I've tried my hand at figuring out how the normal Marx topology could be adapted, but with little luck. There are better brains more steeped in ozone and corona on this forum than mine.
Andy
Sat Sept 07 2013, 07:16AM
Hi Eleccentric
How did you work out the 1mA?
I was basing my measurements or theory on the capacitance value of one plate discharged through a load times the speed of the next plate in seconds.
Andy
Sat Sept 07 2013, 09:57AM
Decided to use a transistor in the setup, this should work
Antonio
Sat Sept 07 2013, 12:41PM
There is an old book entitled "Modern high speed influence machines" that describes techniques to build electrostatic machines, still with classical design, with high current output.
But "high" in this case is really 1 mA for disks with a good fraction of a meter in diameter. For normal hand-cranked machines operating in normal air, 100 uA per section is "high" current. Similar ideas were explored many times, but with few good results. Today there is research being done about the use of electrostatic generators in wind generators and in small generators powered by mechanical vibrations. A DC/DC converter is usually required to reduce the output to low voltage, but it is complicated to make one converting from more than a few kV.
Sat Sept 07 2013, 12:57PM
Eleccentric wrote ...
Could you not just use a string of capacitors, and 'tap' each capacitor in the string for a lower voltage?.....say a string of 200 caps, each with 1000V across it.
Antonio
Sat Sept 07 2013, 01:06PM
Ash Small wrote ...
To take all the energy, you have to reconnect all the capacitors in parallel. The problem is finding a practical way to do it.
Andy
Sat Sept 07 2013, 08:29PM
Hi Antonio
Thanks, will download the book.
Sat Sept 07 2013, 11:23PM
Antonio wrote ...
Agreed, but there are plenty of semi-conductor devices that can easily withstand 1kV
Andy
Mon Sept 09 2013, 01:52AM
del
first  6 7 8 9
