  • Guests: 51
IAmSpock (18)
01/30 Ian (37)
01/30 Lucas (40)
01/31 Mathias (42)
Voltage divider.
Fri Jul 19 2013, 10:05AM
The simple, and reasonably efficient solution, which will also provide mains isloation (I think) is something like a 3.3kVA 240-110 site transformer like this one:
If you shop around you should find one for a few dollars/quid/euros, etc.
StormInABottle
Fri Jul 19 2013, 01:05PM
I cannot purchase from the internet. It must be DIY.
Fri Jul 19 2013, 01:08PM
ExplodingLikeYeah! wrote ...
No, its a commercial website. Just click ADD TO CART and fill out payment information.
Fri Jul 19 2013, 01:56PM
There must be a second-hand toolshop near you, maybe a market stall?
Every town has them.
EDIT: THIS IS ALSO THE SAFEST OPTION, AS IT GIVES MAINS ISOLATION (I THINK), AND 110v IS UNLIKELY TO BE LETHAL IF YOU MAKE A MISTAKE
Fri Jul 19 2013, 03:11PM
ben123324 wrote ...
Please don't... all this talk of 6kW with 50% efficiency is really hurting me inside angry
I agree, to think of such primitive voltage regulation, at such high power, in this day and age.
StormInABottle
Fri Jul 19 2013, 06:05PM
Is there no cheaper option?
Fri Jul 19 2013, 06:42PM
None that is 'safe'
IE non-lethal if you make a mistake.(and 110V isn't completely safe)
StormInABottle
Fri Jul 19 2013, 06:54PM
I use gloves. :). A coward stick. That's it's new name. And i never work on circuits with power going through them. Plus i usually use really well insulated pliers. And the thing will be mounted on a pcb. So i know about safety. And a 1000 pound piece of metal (Joke) isn't exactly practical for a pcb
Ben Solon
Fri Jul 19 2013, 08:24PM
Well neither is a variac, or a 3kw resistor. Maybe a smps, but the inductor would still be large to handle that power. There is no pcb mount option at this level, you need to decide on a safe, efficient solution: a transformer or a smps. We've given you all the practical options, the rest is up to you.
StormInABottle
Fri Jul 19 2013, 08:50PM
So not even a buck converter would work. And none of those solutions would be practical for me. I'm not willing to spend lots of money. But if i think about it for a moment. Designing a 100:50 ratio transformer could be that hard?
