  • Guests: 51
Hamamatsu
2Spoons
Mon Jul 22 2013, 02:35AM
You can recover some MTF resolution by applying a sharpening filter, at the cost of increased noise. The idea is to measure the transfer function (using a sharp shadow edge), calculate the inverse of that, and apply it in an FIR filter. This works, we have done it here, but as i said at the cost of increased noise.
Linas
Tue Jul 30 2013, 05:58PM
well, testing show that it is better when my old detector, even at 4x speed.
Now i have to develop fpga core that could do single point DFT in real time, since my dsp can do 1.2MHz PID loop, but only if it has data inside memory, and simple flag toggle only works to 30MHz at 400MHz core speed
Linas
Tue May 13 2014, 07:22PM
Finlay get it working. I can calculate phase at 207k spectrum acquisition speed, that translates around 500Mbps real time data processing speed from my Sharc DSP, cool huh ?
1400008952 1143 FT155811 Detector1
1400008952 1143 FT155811 Detector2
Dago
Wed May 14 2014, 06:07AM
Linas wrote ...
I have to say that is a beautiful board (I'm a bit of a PCB connoisseur!). Congratulations!
Where did you manage to get the sensor?
Wed May 14 2014, 07:23AM
I have a Gen 0 IR tube here and some assorted linear CCDs if they would help.
-A
Linas
Wed May 14 2014, 08:55AM
Conundrum wrote ...
CCD is pain to interface, also need special amp to get intensity with high dynamic range. go for CMOS type, only two signals, and rail to rail output from integrator, no amp needed for low speed, like TSL1401CL
