  • Guests: 49
Tonic (38)
earth3 (29)
09/09 Tonic (38)
09/09 earth3 (29)
09/13 WarrenR (64)
Low Melting Point (281F) Sn/Bi Solder for SMT.
2Spoons
Mon Jul 15 2013, 02:14AM
I don't see the problem - I've made boards using a Brother printer (copier/fax/printer actually). Also used HP and Sharp printers. What sort of transfer paper are you using? I use the mylar based blue stuff - by far the best in my experience.
Mon Jul 15 2013, 03:11AM
2Spoons wrote ...
the later verisons of the early to mid 2000's (2004-ish) brother printers started using 370 degree F toner, which needed different temp and or pressure points to fuse to surfaces, compared to normal printers of every other type and maker. its widely known to be crap toner for PCB but quite good for text and graphics....
Tue Jul 16 2013, 04:47PM
Soldering went well, got 4 out of 4 leds to work. the low temp solder definately helped. im happy with the result, and it all works, ive made the measurements of V sub f and current to make sure ive got the LEDs bright enough without exceeding the datasheet absolute maximums. The purpose of these LEDs is to indicate the machine states of my drone while in flight, since we multi-rotor pilots dont really have any conventional flying instruments. I dont dare take my eyes off a machine in flight to look at a tablet or laptop screen, for human safety reasons.
test board pics...
1373993261 2431 FT155609 Copper
I forgot Brother toner wont work for TT.
1373993261 2431 FT155609 Dextrin
Drafting it all.
1373993261 2431 FT155609 Hclperox
Crude surface mount board
1373993261 2431 FT155609 Hclperox2
Etching with HCL and Perioxide.
1373993261 2431 FT155609 Testleds1
Measurments.
1373993261 2431 FT155609 Testleds2
Measurements
1373993261 2431 FT155609 Testpanel
F
1373994172 2431 FT1630 Lit1
G
1373994172 2431 FT1630 Lit2
H
lipo
1374006092 2431 FT1630 Batt2
LiPo battery for drone. Should hover 1.5kg for 7+ minutes, out of ground effect.
