  • Guests: 55
12/04 Sulaiman (71)
12/04 teslarevolution (29)
12/04 AromaZ (69)
Dead PT
Sat Jun 22 2013, 09:43AM
johnf: The output voltage of the PT, when in resonance, is limited to a safe value by core saturation.
Sat Jun 22 2013, 11:37AM
It is possible to get more voltage than the core saturation limit, by series resonating the secondary leakage inductance. I think you need a low impedance on the primary to do this though, at least at the resonant frequency. If you were supplying it through a ballast, the series resonance should have been damped.
Sat Jun 22 2013, 01:41PM
Steve, I think the leakage indutance of a PT is so small that the resonant circuit would have a negligible "Q"-factor...
On the other hand, in high-leakage transformers where the primary and secondary windings are separate on the core, this leakage-resonance trick is not possible because at least a part of the core which is directly under the secondary winding will saturate and limit the voltage anyway.
Tony Matt
Tue Jun 25 2013, 02:55AM
I have worked 20+years in a winding workshop.
For motors and tranfomers cclass B winding you may use Taxil, and can free the wiring... you may save and reuse the coppewirer and iron core.
Taxil is a kind ot paint off, caustic soda NaOH
BUT for epoxi, noway, use chisel or make a wood fire.... Then you can reuse the iron core.
