  • Guests: 66
Junky QCW
Mr.Black
Wed May 08 2013, 08:35PM
Mr.Black Registered Member #3960 Joined: Mon Jun 20 2011, 06:27AM
Your QCW DRSSTC looks so beautiful!
I have a lot of problems.I'm building a QCW DRSSTC project.Hoping to get some help.
How much the TC HBridge's bus voltage waveform slope ? It is a linear law?
How to record the tank current waveform envelope?^^
teravolt
Thu May 09 2013, 04:12AM
I am building a hand held version of the qcw that is about the same size as your coil and I was wondering if you would be willing to post a picture of the semiconductor face of your tesla. I was thinking of making my bridge of 4 hgtg27n120bn X 4 for a total of 16 devices do you think that it is over kill? I am trying to gauge how much power it takes to produce large sparks like your gif pictures and how big can they get. Do you think that the length of the arcs are due to the large electrolytic capacitors (energy storage) or the wall power you are supplying? thanks
1368072747 195 FT153579 Qcw
dex
Thu May 09 2013, 10:11AM
dex Registered Member #2566 Joined: Wed Dec 23 2009, 05:52PM
great work and fantastic tesla coil.
generating 7' long sparks in normal atmosfere with less than 100 kV top voltage is an amazing.
Thu May 09 2013, 10:25AM
Performance is amazing! Must be the green topload that does it smile
Fri May 10 2013, 08:32AM
Wow, totally awesome smile.
You mention 300A somewhere, which sounds about right. My original QCW managed only 6 foot sparks (~182cm) with ~270A drive, but it seemed to be going too far out of tune and i didnt have nearly the bus capacitor that you have, so it just never pushed any futher despite longer pulses. I find that adding secondary C helps with the detuning and keeps the primary current significantly lower.
I also am impressed with the size of your setup. Good old aluminum heatsinks will do the trick if the rep rate is low enough smile. We mainly rely on the copper tab of the TO-247 for pulses in the 20mS range, so it really comes down to if your IGBT has a big enough chip or not. It sounds like you are finding out what the absolute max pulse capacity of these IGBTs are!
Intra
Sun May 12 2013, 10:25PM
Intra Registered Member #2694 Joined: Mon Feb 22 2010, 11:52PM
Ээх, какая охуенная тесла.. Просто агонь!!!
zrg
Mon May 13 2013, 02:41PM
zrg Registered Member #4762 Joined: Sun May 06 2012, 05:59PM
Semi-final setup.
The doubling of electrolytics and adding a bigger topload increased the perfomance (230+) cm, but unfortunately there's no place for more capacitance inside the case.
1368455809 4762 FT153579 Dsc 9946
1368455809 4762 FT153579 Dsc 9948
1368455809 4762 FT153579 Dsc 9920
1368455809 4762 FT153579 Dsc 9921
1368455809 4762 FT153579 Dsc 9922
1368455809 4762 FT153579 Dsc 9923
1368455809 4762 FT153579 Dsc 9924
1368455809 4762 FT153579 Dsc 9926
1368455809 4762 FT153579 Dsc 9927
1368455809 4762 FT153579 Dsc 9928
1368455809 4762 FT153579 Dsc 9929
teravolt
Tue May 14 2013, 04:05AM
I think you hold the spark length to secondary height ratio record. Exhalent work, your coil is more of a work of art. Do you plan on releasing any schematics so we can better understand it?
Goodchild
Tue May 14 2013, 07:38PM
Wow, that's some awesome work! And you are only using a single full bridge of transistors? Very impressive work.
dex
Fri May 17 2013, 08:36AM
zrg wrote ...
The current limiter is set to 300A, which gives us ~60 kW of peak power through buck. It's amazing how much these small transistors can withstand cheesey However, in the end it banged with several kJ from lytics coming into my poor ears.
well,it would be interesting to estimate energy used to create 7' spark.
W=∫P(t)dt
assuming ~15ms ramp,and 60 kW peak power with linear rise of input power that would give:
W ~ 60kW×15ms/2 = 450 J
does this sound ok?
