SSTC bridge blew up
Atomic
Registered Member #8743
Managed to drive the rod and it was much easier than I thought.. Just used a garden hose to soften the earth, pressed down the rod a bit, removed for the water to penetrate, repeated again and again. Didn't even have to use a hammer!
Left out only 10cm of the 2.4m, to attach the wire. I might use 2 stranded wires (about 13AWG), as suggested. They'll have to be some 10m long, hope it all works out!
