  • Guests: 79
Rotary spark gap help.
the mad scientist
Sat Mar 16 2013, 05:20PM Print
the mad scientist Registered Member #3768 Joined: Tue Mar 22 2011, 12:46AM
I am wondering what would I use to mount electrodes onto the rotating disk...
Sun Mar 17 2013, 12:37AM
Generally, i've seen them where they press fit the tungsten rods directly into the rotor disk and then use set screws on the outside edge of the rotor for added security.
the mad scientist
Sun Mar 17 2013, 04:28PM
You see I don't have access to those type of tools. I don't even know how I am going to make the disk...
Sun Mar 17 2013, 05:36PM
Check out the two rotary spark gap variants that Terry Blake made about 10 years ago. These work great - i've built the second type for an ASRG gap 10 years ago following his design and it worked great for up to 3kW operation.
Just be sure to put these in shielded (lexan for example) enclosures as if the rods to hit each other, you could have flying tungsten which is very brittle and sharp.
the mad scientist
Sun Mar 17 2013, 06:54PM
What should I make the disc out of though?
Mon Mar 18 2013, 01:14PM
the mad scientist wrote ...
If you go the Terry Blake route, then you don't need a disk. You can just just square polyethylene plastic which is what he used.
For a conventional rotary spark gap, the materials commonly used are Phenolic (easy to machine) or G-10 (difficult to machine)
the mad scientist
Mon Mar 18 2013, 06:25PM
Ok sounds good, I have another question, I have 4 pure tungsten electrodes for me to do the Terry Blake rotary spark gap. But for the propeller peice would it be alright if I just used brass?
Mon Mar 18 2013, 10:18PM
For propellar, use tungsten as well. I believe Terry used 1/8" diameter tungsten rods.
the mad scientist
Tue Mar 19 2013, 01:36AM
Is that a must because I don't think I can get my hands on any more pure tungsten in time, are you sure brass wont suffice?
Tue Mar 19 2013, 03:05PM
mcmaster-carr sells the 1/8" tungsten rods.
