  • Guests: 78
01/12 RoV IW3IPD (63)
Moron Alert
Mon Aug 28 2006, 12:19PM
Only way t get shocked from a single wire would be displacement current to surface of his body. Anyone has clue of average human self-capacitance?
Say it's 1nF, being hung on 25kV 50Hz AC wire:
Z = 1/6.28*50*0.000000001 = 1/0,000000314 - guy's capacitive impedance would be
3 184 713 ohms. Current is 25 000/3 184 713 = 7,8 miliamps. Probably not pleasurable but not lethal yet.
For birds and small animals with capacitance of just few tens of pf effect probably isn't bothering.
And he would also see an initial 'shock' once relatively high current dumps into his capacitance when he touches the wire (altough that wouldn't be the biggest problem at time)
Bored Chemist
Mon Aug 28 2006, 12:45PM
"You have to remember that charge is relative..."
If an object has more electrons than protons (in the nuclei of its atoms) then it has a negative charge.
Potential is relative; charge is absolute.
It's perfectly common for a person to get charged to much more than the few KV that this idiot by static.It stings a bit but it doesn't do any harm. 5KV is 5KV, it doesn't matter if you get charged from a nylon jumper or a power line.
Ben
Mon Aug 28 2006, 04:39PM
Ben Vigilatny
Registered Member #17 Joined: Thu Feb 02 2006, 02:47PM
rennoC evetS wrote ...
EVR: The arc between the helicopter and the line most certainly is due to the line voltage and the helicopter's capacitance. Think of the chopper as a humongous Tesla coil topload. I'm guessing this because
a) there's a helipad near my house and I don't see hot white arcs jumping to the ground any time a chopper comes in to land.
Depends on the power line(and perhaps the helicopter) whether the arc is from the helicopter or the line. A CH53E develops about 200 kV. I'd guess the helicopters used to service HV lines are designed to prevent static discharging(so no current flows once they reach line potential). That would mean they probably develop higher voltages than most.
google search
wikipedia
Wikipedia wrote ...
The job of the Static man is to use a grounding rod to attach to the hook so that the static electricity conducted by the helicopter is grounded out and does not end up killing a Marine.
Bored Chemist
Mon Aug 28 2006, 05:22PM
"Anyone has clue of average human self-capacitance?"
Estimates on the web vary, but the consensus is about 100 - 300 pf so the current would be less than a couple of miliamps.
20 feet above ground is more of a problem than 20KV above ground in this instance.
Simon
Wed Aug 30 2006, 04:55AM
You don't need to make the calculations. EVR made this point earlier: try charging yourself to something like this 25kV from a VDG. The situation, and hence capacitance, is different but things won't be worse.
