Passing HF current through your body
Uspring
Fri Sept 27 2013, 12:37PM
Registered Member #3988
Eric wrote:
hmmm I seem to be alive. I gladly acknowledge that.  QCWs run at high frequencies and don't have as large peak currents as short bursting TCs. Probably they will tend to burn rather than shock you.
radiotech
Fri Sept 27 2013, 08:31PM
Registered Member #2463
I you had a tank of seawater how could you measure the voltage gradient in the water at various depths' given that point of entry was something the size of a human arm reaching up from the water and grasping the Tesla terminal ?
Given there was a voltage gradient in the water, the water would heat up. Now we know it wont simply because even a large TC only outputs small currents,
Yet, a lamp touching the water surface lights in this experiment, but cant light inside the water.
