  • Guests: 28
Ben7 (29)
12/17 Ben7 (29)
12/18 Skywarrior (52)
12/18 Dark Horse (54)
Passing HF current through your body
Mon Mar 11 2013, 12:33PM Print
Hi all
I found this interesting paper:
It has an IEEE/ANSI recommendation for the maximum high frequency current that can safely be passed through the body. At VLF frequencies, you can have roughly 1mA for each kHz of frequency flowing in a limb. (Limited by current density in the ankle or wrist. A more detailed discussion is on page 33.)
This seems to imply that you can pass a few hundred milliamps through your arm at Tesla coil frequencies, and so it is actually quite safe to light a low-powered filament lamp with current passed through your body. I've done it with a 30W, 240V lamp and suffered no ill effects. smile
Mon Mar 11 2013, 01:45PM
Interesting paper.
What do they consider VLF frequencies?
Physics Junkie
Mon Mar 11 2013, 01:54PM
Yikes, so who wants to be the guinea pig on this one? smile
ScotchTapeLord
Mon Mar 11 2013, 08:02PM
I don't know, this guy says higher frequencies are worse:
Much more credible than IEEE! ;)
Mon Mar 11 2013, 08:22PM
LMAO - I want that guy as my Tesla Safety Officer !! Nothing could go wrong !
Tue Mar 12 2013, 10:16PM
Hi Steve and Everyone :)
Funny how in another thread I've read a claim of maximum permissible H field exposures on only a few V/m at Tesla coil frequencies (which, even more absurdly, decreases with the frequency!). In any case, I wouldn't take any of these as a rule above some basic sanity and ohm's law.
When lighting incandescent bulbs with Tesla coils, one would need to take care that his arm doesn't end up dissipating many times the power that's already dissipated by the body, which is 100W or so. If typical arm resistance is in range of few hundred ohms, the current indeed resolves to a few hundred miliamps. I certainly wouldn't take the above rule as meaning that one can safely pass 10A at 10Mhz through his arm!
I'm actually not convinced that frequency may have much to do with this, as long as it's well above cutoff frequency of the nerves.
As Steve already said, these experiments tend to concentrate the power in fingers, fists and ankles and that's likely the first place where damage would occur.
I once lit a 100W bulb that way for quite a long period of time this way by holding it only by a thumb and index finger, and got a weird pain in the thumb joint which went away another day. Couldn't figure it it was even related at all, but it till made me to put some sense into the thing, so I later used a 25W bulb and a big copper pipe as an electrode which I held firmly with both hands. This is the setup that I'd recommend for anyone who really wants to replicate this experiment. If I had to put a line somewhere, I'd call the maximum permissible rf current through palms about 100mA, because that was what I was able to pass without any ill effects!
Cheers,
g8gon
Wed Sept 25 2013, 09:05PM
g8gon Registered Member #2370 Joined: Fri Sept 18 2009, 02:15PM
i have on occasion drawn arcs from a cw powered coil @ 2kw with a hand held 5ft flourescent tube..
no burning hands etc but i always suffer chronic hoarsness later in the day and for a few days after, such that i try to avoid the party tricks as much as possible now.. anyone else suffered hoarsness i wonder.. is it arcing from the tonsils i wonder maybe keeping the mouth shut would be better.. smile alec
Wed Sept 25 2013, 09:45PM
I think hoarseness would most probably be caused by breathing the ozone and oxides of nitrogen from the sparks, both toxic gases.
I once got a really bad sore throat from practicing the Tesla guitar show in a room with a smoke machine and poor ventilation.
Wed Sept 25 2013, 09:56PM
I have seen people pass amps of RF current into their hand at MHz frequencies, of course it was always just for a moment smile
BigBad
Thu Sept 26 2013, 01:07AM
I realised a while back that even when you hold a fluorescent tube near a Tesla coil and it lights up, of course the power/current for that is actually going through your arm; even though it's capacitively coupled through the glass.
I can't remember exactly how I did it, but IRC I did a BOTE on that current, and found it was much closer to the fatal limit than I would have preferred. wink
IRC it was a few tens of milliamps, I may have done the calculation wrong of course.
