  • Guests: 108
12/29 Cprossu (40)
12/29 Kokamo (46)
12/29 GalliumMan (60)
better insulation than HV oil??
Thu Feb 28 2013, 10:27PM Print
Andre Registered Member #6921 Joined: Wed Sept 26 2012, 07:47PM
anyone knows where can I get some better insulation than HV oil? or the name of a epoxy that I can use, I'm working at 80KV
GrantX
Fri Mar 01 2013, 02:21AM
Andre wrote ...
Fully dried oil intended as HV insulation has an incredibly high dielectric strength, something on the order of 10-15 MV per metre. Are you sure that your oil is clean and free of moisture? If your working with a transformer or similar, have you pulled a vacuum over it to eliminate air pockets? Oil should be more than enough insulation for 80kV.
If you need something stronger than oil, perhaps a very thick layer of super-high-quality PTFE sheeting? The trouble with solid dielectrics is getting a good seal on the surface you're insulating, to eliminate surface tracking. I've had a coil fail because it surface-tracked underneath the Teflon tape, something I've never witnessed with oil.
Fri Mar 01 2013, 08:38AM
I read recently that boiled coconut oil is better than standard transformer oil, but I've not tried it. See the link in my thread on self resonance.
Fri Mar 01 2013, 02:30PM
Fluorinert if you're able to have it submerged.
Fri Mar 01 2013, 03:06PM
Thanks guys I found this list so I'm going to try a few things
Dielectric strength comparison between materials
Material * Dielectric strength (kV/inch)
Vacuum 20
Air 20 to 75
Porcelain 40 to 200
Paraffin Wax 200 to 300
Transformer Oil 400
Bakelite 300 to 550
Rubber 450 to 700
Shellac 900
Paper 1250
Teflon 1500
Glass 2000 to 3000
Mica 5000
and also this list Link2
transformer oil seems to be stronger than Fluorinert according to the link
Fri Mar 01 2013, 11:45PM
20 kV/inch in a vacuum... seems legit mistrust
I've had really good experience with paraffin wax at high voltages/high frequencies, but its physical properties and melting point can be a problem.
Sat Mar 02 2013, 12:05AM
Dr. Dark Current wrote ...
My research suggested 200kV/cm....or 1MV/2 inches
I'll try and dig up some links when I'm sober in the morning. smile
Daedronus
Sat Mar 02 2013, 10:56AM
define vacuum..... mistrust
below 10^-3 torr it's very hard to get any kind of discharge, this is why we use thermionic emission in x-ray tubes.
Shrad
Sat Mar 02 2013, 12:02PM
shellac is easy to obtain in powdered form, used for pyrotechnics widely
Sat Mar 02 2013, 01:50PM
One thing to keep in mind - if you are planning on potting or submerging any high frequency circuits - be sure to account for the added dielectric constant as this will add a lot of stray capacitance in your circuit.
