  • Guests: 41
oucivileng (39)
01/27 muller (38)
01/27 Dr. Mario (38)
01/27 Ben Solon (30)
Use a P-Channel Jfet as a variable resistor?
GammaRay
Mon Dec 31 2012, 07:31PM Print
GammaRay Registered Member #5323 Joined: Fri Jun 15 2012, 02:14PM
I checked the archive before posting. I'm powering a tiny 3v DC motor/fan blade with an AeroGel Super Cap (5v@5F) and would like the motor/fan to spin as long a possible between chargings. Torque and RPM is not the issue, but obtaining the maximum length of operating time is the goal even if the motor turns at a leisurely slow speed, that is okay. The motor/fan spins at an acceptable RPM all the way down to 0.4v. (Already tried a PWM approach, but the PWM circuit I have requires 5v to operate and fails at 4.5v).
I'm wondering if a P-Channel Jfet could be used as a variable resistor to limit the motor operation to a slow, yet constant speed throughout the Super Cap's 5v-0.4v discharge cycle? Sanity check requested. Thank you.
Adam Munich
Mon Dec 31 2012, 07:35PM
Since a resistor would just burn any power not consumed by the motor, you're not going to get a longer run time by using any form of resistance, regardless of what the component is. All you'll have is just a motor with less torque.
Try a PWM circuit with a CMOS 555 timer and a logic-level mosfet. That should accomplish what you're after.
Myke
Mon Dec 31 2012, 08:16PM
Gren wrote ...
You do get less torque due to the reduced current but that would also increase the time that it spins since the energy is drained from the cap at a slower rate. It's just not very efficient.
Gren wrote ...
He did try PWM but it had problems as he described. Maybe try to use separate caps for supplying the switching control so that the lower voltage doesn't cause the logic to cut out? You could also try to use 3.3V logic things which should give you more headroom. With this, you could probably get a lot longer run times since you have more control of the rate of draining the cap. You could run the motor at the minimum acceptable RPM meaning short pulse lengths which also might improve the switching control current drain (depending on what you use for PWM).
Mon Dec 31 2012, 08:21PM
A series resistor would increase run time a little by running ata lower current
it would be good to short out the resistor at low capacitor voltages
For ultimate long run-time it comes down to stored energy
0.5 x 5 x 5^2 = 62.5 Joules
being delivered to the motor at minimum reliable power, e.g.
1V x 10mA = 10mW
If you could convert all of the stored energy at 100% efficiency
Run Time = Energy/Power = 62.5/0.01 = 6,250 sec = 1.736 hours .. etc.
If you make a 'Buck' converter that works down to 1.5V input
9% of the capacitor energy will be remaining.
e.g. 91%Energy x 63%Efficiency = 1 hour @ 1V/10mA
I'd expect there to be loads of ICs and fierce commercial competition in this area.
any special reason for p-channel jFet?
this is not the first type of transistor that would have come to my mind for such an application.
an n-channel jFet such as j310 (or similar) could be used as a sort of linear regulator,
but I think that an LDO linear regulator is cheaper!.
I'd start by looking at 'Energy Harvesting' technologies. e.g. Link2
P.S.
two (or maybe three) red led in series with the motor would be almost as good as a resistor
(IF the motor current is less than the maximum allowed led current)
shorting/switching an led out as the capacitor voltage falls would extend run time.
Simple and easy to demonstrate BUT definitely not as efficient as a switch-mode converter.
Tue Jan 01 2013, 02:02AM
N channel would work equally well, presumably here he is trying to use high side switching.
I've used an LM317LZ before as a temperature sensitive fan controller and this sort of worked.
Daedronus
Tue Jan 01 2013, 10:05AM
why not use the motor itself as a switch?
Dr. Slack
Wed Jan 02 2013, 05:36AM
Important things being equal, like the same motor and the same power source, you will get longer run time from a well-designed PWM than you will from any sort of variable resistor.
However, if you don't have a well designed PWM, but one that stops working in a region where you still want it to be working, then you need a better design of PWM.
For operation at very low input voltages, a PWM will effectively have two outputs, one for its own bias supply, and one for the load. Obviously there is a startup problem if you want it to start at very low volts, but for converting a discharging capacitor, it sounds like there's initially enough voltage to make it work.
If your motor will run at 0.4v, then being able to PWM/buck from 5v to 0.4 instead of drop from 5v to 0.4 will give you 10x the run time.
GammaRay
Fri Jan 04 2013, 02:43PM
Here's what I've found so far. I used a Decade resistance box to manually guadually reduce resistance from the Supercap to the motor as the Supercap discharged from 5v down to 0.4v. Although quite wasteful, it did cause the motor to operate longer by a factor of 2 by causing the motor to turn quite slowly. Alternatively, I used a buck/boost circuit to provide voltage to a PWM circuit, but alas, the combined current drain of the buck/boost and the PWM results in dismal time duration (worse time than with no circuit at all). I agree that a properly designed PWM that operates to very low voltage is my best bet. I would like to purchase an off-the-shelf & assembled PWM that will operate down to around 1-2 volts (if such a circuit exists) can anyone point me in the right direction?
Adrenaline
Fri Jan 04 2013, 03:16PM
Adrenaline Registered Member #235 Joined: Wed Feb 22 2006, 04:59PM
I haven't researched a ton or know all of your requirements, but Linear has some devices:
Fri Jan 04 2013, 03:27PM
Have you looked at low voltage motor driver ICs like DRV8832? Link2
