  • Guests: 54
Gavin (49)
Froskoy (33)
UnHappy1 (59)
07/16 Gavin (49)
07/16 Froskoy (33)
07/16 UnHappy1 (59)
My first DRSSTC: EVR MicroBrute
Fiddy
Thu Dec 27 2012, 11:57AM Print
Fiddy Registered Member #8817 Joined: Mon Dec 17 2012, 05:16AM
G'day blokes,
Im on holidays :D So that means all projects will be in overdrive!
Working in induction heating as an electrician ive been keen to build my first tesla coil so I bought the Microbrute kit from Eastern Voltage Research.
Frontpage MicroBrute260x200
Kit arrived:
DRSSTC
Now this kit is a 110V job, and Australia being 240V i bought a 2kW 110V step down tranny.
01 12
The kit came with a plastic top load must be laced with aluminum foil, which doesn't look too bad but i really love the spun aluminum toroid's out there so i bought one 8" x 2.25". This will increase the secondary capacitance but i can tune the primary to suit.
7367 1
I also need a cooling fan to the heatsink cooling the 2 IGBT's so i bought a 6" Dayton rated at 239CFM.
60 3
Built the interrupter remote:
Remote
Made a winding jig and wound the secondary by hand (30AWG 10" length, 3.22" diameter)
Secondarycoil
Here's a enclosure idea im working on:
Layoutresize
PCBLayoutampFanresize
Wound the primary and wrapped the top load in aluminum duct tape.
Microbruteprimaryseconday
Got a 4" cooling fan until my 6" one arrives:
Coolingfan Zps45bd9db8
Finished the circuit board:
Pcbcomplete Zps3ae3f0a2
Here are my calculations for the new Top Load:
Secondary
Standard Top Load
3.22" x 10"
Capacitance = 5.792pF
Turns = 1000
Wire = 30 Gauge
Diameter = 3.22"
Length = 10"
Inducatance = 22.64mH
Resonant Frequency: 439.5khz
New Top Load
3.22" x 10"
Capacitance = 8.897pF
Turns = 1000
Wire = 30 Gauge
Diameter = 3.22"
Length = 10"
Inductance = 22.64mH
Resonant Frequency: 354.6kHz
Primary
Standard Primary Turns
4" x 0.2424"
Capacitance = 0.075uF
Turns = 3
Wire = 12 Gauge
Diameter = 4"
Length = 0.2424" (0.0808" per turn)
Inductance = 1.917mH
Resonant Frequency: 419.7khz
New Primary Turns
4" x 0.29088"
Turns = 3.6
Wire = 12 Gauge
Diameter = 4"
Length = 0.29088" (0.0808" per turn)
Inductance = 2.65uH
Resonant Frequency: 357khz
My first run:
Tesla1 Zps34ff625c
Installed the spun toroid:
Toroid Zps8c5186de
Some photos of it running:
Arcs1 Zpsa6b7bdbd
Arcs2 Zpsfd5819cb
I have ordered the enclosure for the unit, but it hasn't arrived yet.
Stay tuned for more progress,
Fiddy.
Sigurthr
Fri Dec 28 2012, 03:32PM
Awesome work, Fiddy! I need to get one of these one day.
I can't remember, is this your first plunge into TCs or did you build a SSTC or SGTC before this?
Fiddy
Fri Dec 28 2012, 03:48PM
Theres a user name i know!
Yeah i did, a small audio modulated SSTC "plasma speaker"
Plasmaspeaker2
Sigurthr
Sat Dec 29 2012, 02:35PM
Hehe, yup this is one of my more frequent haunts.
Ohh that's right, the cute blue one. I love small TCs, so awesome. The physical design aspects to your projects always amaze me. I can do great things with electronics but cases, stands, bases, etc are beyond me.
You're familiar enough to be safe then, that's good. HV high e-field RF tends to do things one would not expect.
Fiddy
Sat Dec 29 2012, 02:39PM
Shweet!
Hehe thanks, i the case came with this unit, i just assembled it.
Most of the time its just send a diagram to the plastic mob and you get what you want in the mail :D
Yeah funny that, it does crazy things at work on our 3MW induction furnace.
