  • Guests: 45
01/12 RoV IW3IPD (63)
transformer width
Newton Brawn
Sun Dec 23 2012, 04:19AM
For practical purposes, winding without impregnation or with just a coat or spray of alkid vernish, as spar clear transparent :
-- using 0.2mm kraft paper between layers, max voltage between two sequencial layers are limeted to 500V
-- using 0.1mm polyester (Mylar) film between layers, max voltage between two sequencial layers are limited to 1100V
- Using 0.2mm polyester between layers, max voltage 1600V,
The insulaton has to be extended 3-4mm in excess of the layer lenght, to create a shirt between the layers (the crepage is about 300V/mm)
Without more info from your trafo is impossible to help.
Provide complete data and pictures about your trafo.
---define the secondary voiltage
---define the number of sercondary turns
--- define the secondary wuire diameter,
---- sketch of your trafo core and DIMENSIONS
Mon Dec 31 2012, 03:18PM
Andre Registered Member #6921 Joined: Wed Sept 26 2012, 07:47PM
Thanks for the information, do you know where can I get 0.2mm polyester sheet? I'm also trying to get 50KV secondary, wire is 38awg, and I can do about 200 turns per layer, and the core is Link2 81-33-16
Tony Matt
Tue Jan 08 2013, 11:55PM
Andre;
1- wire #38 is very ard to work, evem for experieced coilers. I might suggest you not go over #28AWG wire.
2 -0.2mm polyester or mylar film you will get at a workshop that repair small tranformers and rewind motors and generators
It is cheap, about US$2 for a 900mmx120mm sheet.
If you core is smaller than 50mmx50mm , use 2 sheets of 0.1 to compose a 0.2mm thick.
Emgineering drawings use Mylar paper, maybe you can buy the Mylar at art supply store.
A preliminar test may be tone using kraft paper pre impregnated with alkid vernish.
By the way....
---post a sketch of your trafo core and DIMENSIONS
Wed Jan 09 2013, 03:22PM
Tony Matt wrote ...
Andre;
By the way....
Thanks for the info Tony, I will try that, so far I got to 20KV I'm trying to get to 40KV I had try to stack them together the 2 20KV coils but that didnt work so I had starte a new thread on it
, so I'm going to see if I can build a 40KV coil with mylar film, I'm no experience winding coil but I had successfully winded a few coils with 38AWG and got to 20KV with it :)
Linas
Wed Jan 09 2013, 04:25PM
My idea for transformer
Only thing i don't like i will get 33KV to 6mm of plexiglass, but i guess that is ok
Wed Jan 09 2013, 04:31PM
Linas wrote ...
what's your turn ration? how many turns you have on the secondary, I have the same core, I just having a hard time understanding your picture,
Linas
Wed Jan 09 2013, 07:26PM
i should get around 1700T
so i will make secondary to get >30KV ( i have 160V half bridge )
so i need around 20V/T that means 8T primary
I will cut 1mm Plexiglas and glue it , and use acrylic tubes for ferrite insulation.
It will have construction as flyback, 11 vertical windings joined together, it should give low C
Wed Jan 09 2013, 07:33PM
Linas wrote ...
I'm curious about your transformer, what calculations did you do to come up with those numbers?also are you using anything as reference?
Linas
Wed Jan 09 2013, 07:43PM
Andre wrote ...
simple math. I don't know will it going to work.
All i know i have Half bridge current mode SMPS to drive transformers, i have 160V voltage swing.
since i need 20V/T primary simply 160/20=8T
Same for secondary.
Resistance will be low for 30KV (~500R secondary resistance ,so 66mA for 2KW should give 2W , no problem)
Only consideration i have is resonance, it will lower my V/T ratio, i guess i should use resonance in my favor to get more V/T.
Time will tell am i right...
In picture was old idea for 60KV transformer, but core is to big, i can get same power for smaller size.
1357760598 1143 FT147810 P1000626
Wed Jan 09 2013, 07:48PM
I tried to stack them together, the way you are showing in the picture but somehow it does not work, please post pictures when you get it working, I will like to see this is my design:
0029
