  • Guests: 52
01/12 RoV IW3IPD (63)
Ignition coil driver?
Platinum
Thu Nov 29 2012, 05:31PM Print
There's been an ignition coil sitting in my junk box for months, and I've never driven one at they frequency they like. Only on ZVS (I couldn't get ZVS frequency quite low enough.) So I want to dive it via dimmer switch.
I'm going to buy one of them tomorrow at B&Q, should I get the highest wattage one? and also what capacitors do I need to use in series with the coil? And also is there any type of dimmer switch that only works with this type of driver?
GrantX
Fri Nov 30 2012, 02:35AM
I believe you need a trailing edge dimmer (that means it cuts the waveform short after allowing it to rise slowly. A leading edge dimmer will switch on hard then allow the waveform to drop slowly to zero). This resultant sharp waveform allows flyback style ringing. I used a 400W dimmer, but you might get away with using a smaller one.
Usually the best cap is an AC motor run capacitor, some where from 1uF to 10uF, with a decent voltage rating. When I played with the dimmer circuit I used a 450VAC 4uF PP motor run cap. The cap is essentially just current limiting, so you just pick a rugged cap of suitable ratings.
As usual, take precautions when working with mains power, it may be best to fit a bleeder resistor to the cap, believe me a few uF at a couple of hundred volts hurts like hell.
Eventually my dimmer gave out and died, for unknown reasons. It could perhaps be reasonable to protect the dimmer with a snubber of some sort?
Platinum
Fri Nov 30 2012, 09:39PM
They are cheap enough so I won't mind if it does give up. I'll buy a 700watt one tomorrow, also will mkp or MOC's works?
zippotix
Sat Dec 01 2012, 12:03AM
zippotix Registered Member #5208 Joined: Thu Jun 07 2012, 06:12PM
MOC will work. The wattage should be above 400, if I remember correctly, I used to drive a ignition coil with a 400W dimmer and 1uF MOC, and it runned fine, no overheating or anything.
Platinum
Sat Dec 08 2012, 10:56PM
Right then what do I do, the dimmer has L1, L2 and com, can anyone show me a simple schematic for this?
zippotix
Sat Dec 08 2012, 11:12PM
I have the old type of dimmer, just two connectors and some clamps for mounting. Anyway, the dimmer must be in series with mains and capacitor, you could try using L1 and L2, im not sure what this com is. Here is a simple schematic Link2
The cap in this schematic is rated at 600V, but 2100v MOC will be just as good if not better.
GrantX
Sun Dec 09 2012, 01:54AM
Hmm, all dimmers I've encountered only have two connections, to allow the dimmer to be wired in series with its load. However it is possible that other dimmer models may need a neutral connection (com), however I can't be sure why.
Also, an interesting note: All ignition coils I've tried that possess a FULL core, without air gap, which are mainly the "high performance" E-core coils (and perhaps C-core) perform very poorly on a light dimmer, possibly due to saturation, honestly I don't know. In order to achieve a decent spark you will want the old oil-can type, which only has a straight piece of iron for a core.
Platinum
Sun Dec 09 2012, 10:05AM
The type of coil I have is old I think, it's shaped like a taller thinner pop can. It's the old type.
Mon Dec 10 2012, 11:32AM
Platinum wrote ...
There are two basic types of these ignition coils: the ballasted, and the unballasted.
The ballasted type has a lower primary impedance and is designed for operation in low battery and hard-to-start cold engine conditions, where it allows a bigger spark at start up. Once the engine has started, a relay connects a ballast resistor in series with the coil primary, reducing its current. If a ballasted type were to be used without the ballast resistor, it would overheat and perhaps damage the distributor points and erode the sparking plugs too.
The unbalasted type does not have this high power at start feature.
The HV experimenter will get bigger sparks for their money from the balasted type - used without the ballast, of course! smile
Newton Brawn
Sun Dec 23 2012, 04:35AM
Hi !
Some old ignition coil are oil filled and aluminun case that are connected to the primary and secondary. SOOoo be careful to avoid the electrocution or short circuit,
