  • Guests: 58
Weird intermittent problem with a DRSSTC driver (edit4: fixed?)
Kizmo
Sat Nov 09 2013, 11:21AM
Some of those scope shots do look very familiar!
I will try to see what happens if i put a power resistor across the bridge output. This may just explain why it works on ud1.3 since it has much more sensitive feedback.
Kizmo
Sat Nov 09 2013, 05:08PM
5k 20W resistor over the H-bridge output did the trick!
Now its nice and clean running at any settings. Phew!
Only took like 3 years and 3 entirely different boards to get this thing figured out..
Hydron: PM me your paypal address (if you have one..) I want to give you a small gift :p
Sat Nov 09 2013, 09:48PM
This is very exciting news :)
I hope Steve Ward will one day find time to update his website to contain all links to the vast amount of useful information he have online but unlinked :)
I will report back when I have my driver back from Sync.
Sat Nov 09 2013, 09:57PM
Hehe, good to hear you got it fixed. Strange that since I started thinking about DRSSTCs (though still not built a serious one), I've always seen the need for a discharge resistor which sets the initial charge on the cap. But I have not linked it with your problem, even though the solution was at the back of my head all the time.
Hydron
Sun Nov 10 2013, 05:51AM
Glad to have been able to help sort this frustrating problem. On the bright side, it sounds like Kizmo has a spare bridge and controller for another coil (twins?)!
In testing my coil I hadn't noticed any issue with startup at certain initial voltages, but I had noticed changes in the voltage spikes for the first cycle or two, depending on initial voltage. As this wasn't causing me any issue I didn't bother investigating further at the time.
I subsequently came across Steve's paper while looking for something else, and it inspired me to add a resistor to my bridge when I made some other changes to it. I haven't yet investigated the effect it had, though I intend to do so, as it could be helpful for perfecting phase lead on early cycles.
Anyway, credit is definitely due to Steve Ward for his investigation, and to the other contributors to this thread, it was just good luck that I'd been thinking about the capacitor voltage issue when the thread got new replies and I checked it!
Kizmo
Sun Nov 10 2013, 05:09PM
Aaand the plot thickens.
After getting this UD2.1 i got from slawinski running fine I went ahead and took my trusty old trouble maker UD2.5 out and guess what: It still wont work correctly!
Now it starts fine but still skips half cycles, switching several times at transitions and other weirdness described before. Then i swapped Slawinskis UD2.1 back and it works really well again.
WTF?
Intra
Mon Nov 11 2013, 07:05AM
Intra Registered Member #2694 Joined: Mon Feb 22 2010, 11:52PM
check the interrupter output PWM generator signal. 555's out or whatever you use.. once upon a time, I had issue, that some positions of uSec had in 1 pulse multiply - 20-30 same uSec pulses with few off time parts inside 1 pulse. that's was bad 555 timer.
Kizmo
Sun Jan 05 2014, 09:27AM
I think this issue is finally fixed for good.
For some reason with phase lead enabled it required even heavier bleeder resistor. Right now everything works just beautiful and phase lead does its thing.
Final bleeder resistor was 4x 10k in parallel. Works well up to 700V bus.
1388914036 599 FT144747 Burstmode1
