  • Guests: 51
Weird intermittent problem with a DRSSTC driver (edit4: fixed?)
Kizmo
Sat Aug 31 2013, 01:02PM
I think the switching noise problem was something that mr. Ward had to correct in one of his UD2 revisions.
"C33 controls a "no switch" time after each output transition on the comparator. Originally i found C33 could be just 220pF,
but recently using CM600DU-24NF modules with a loooong 1uS or so delay in switching, i found i had to boost C33 up to 2.2nF.
This provided a longer period where the comparator has high immunity to noise, and without this there was severe "glitching"
where the IGBT switch noise caused the comparator to switch several times instead of once per half-cycle."
Thats pretty much what my driver is doing. Only problem is that i have tried C33 values between 200p and 2n with no change.
EDIT:
Since this is starting to look like a noise problem i think its time to try to improve the shielding by a lot. Currently I have only the driver board inside of the metal box (mainly because fiber rx does not like electric fields). That works well for UD1.3. But should i have stuff like gate drive transformer, low voltage supply transformer and AC input filter inside of the box as well? Also i could convert feedback and overcurrent detection transformer leads from twisted pair to coaxial.
And how about proper grounding? I can see very potential switching noise loop in my current grounding style where I have IGBT heatsinks, driver box and mounting plate tied to mains ground. Also there is a clip-on emi filter ferrite on gdt primary leads and 100nF cap from Bus- to heatsink.
Sat Aug 31 2013, 02:42PM
Steve Conner wrote ...
Well, it would be easier to debug the problem if the scope results actually showed it. frown
What we are trying to establish is a chain of causation. We have the symptoms, we are trying to figure out the root cause. The problem is that the whole system is one big feedback loop, so the chain of causation could be circular.
I would be interested to see what happens when the feedback input is driven from a signal generator as opposed to the CT. This breaks the feedback loop so you can rule out any circular arguments.
I would also investigate the possibility of the switching spikes from the bridge getting back into the comparator. They can be pretty violent especially near the beginning of the burst when there's not enough current to achieve smooth commutation. And, now the comparator has hysteresis, a switching spike could permanently flip it instead of just temporarily glitching the output. (Did the UD1.x have hysteresis?)
The amount of switching spikes present in your CT signal is a system level issue, mainly down to your shielding and grounding schemes. But the driver's sensitivity to them is another matter. My PLL driver uses the type-1 phase detector which works on the average value, so it ignores the spikes completely.
Well... this is what the scope shots look like :)
The spike that appears at the output from the AND gate, it is only coming from pin3, there is not this spike present at pin6.
As my vacation is over and I start travelling again, I have packed the driver up and sent it to a German laboratory for tests. You might know this lab as being run by Sync :)
Kizmo
Sat Aug 31 2013, 04:17PM
I tried to shield everything to mains earth grounded foil and even made Faraday shielded feedback transformer just like mr. Conner suggested.
Absolutely no change. Still as bad as it is without any shielding.
1377965794 599 FT144747 O6uzbkm
This must be by far the ugliest thing i have made.
Sat Aug 31 2013, 07:27PM
Kizmo,
If I might add . . . if everything appears to be working correctly, and you are just getting "shitty" looking waveforms, a lot of the times it can be a result of just poor measurement equipment / practices.
A DRSSTC is an extremely noisy device and noise can be induced all over the place, including on the probes and ground clip loops themselves.
So when looking at your measurements, make sure what you are seeing is actually real, and not just an artificat from a noisy environment or improperly placed probe / ground clip etc....
If you can, try to scope what your actual ground plane looks like. You could be getting common mode spikes that are appearing on everything and not really having an effect on your actual circuit.
Kizmo
Sat Aug 31 2013, 07:59PM
EasternVoltageResearch wrote ...
Kizmo,
Thank you for the reply.
Yes I am fully aware that these things are awful common mode noise generators. And thats why i take most of my measurements with high voltage differential probe which has excellent common mode noise rejection so i am expecting that what i see is more or less actually happening. These measurements can also be replicated with 3 different oscilloscopes.
And it is pretty easy to tell even without scope that this thing is far from happy runner. As we all know, normal DRSSTC should sound like nice and steady BZZZZZZZZ no matter what pulse width you use (of course longer pulse -> louder). Both of my UD2.x boards switch all over the place, skip entire primary current cycles, miss start of the bursts and do all kind of really weird stuff. I can hear and see the problem without any measuring equipment. It sounds like brbprp-ttttt-zz-brbrbr-zzz-bzz and i can see primary wires twitching as the sound changes :D
Some pulse widths seem to be working better than others as you can see here. Red trace is the primary current from pearson and yellow trace is actual H-bridge output voltage from differential probe.
1377978932 599 FT144747 Burst
1377978932 599 FT144747 Burst2
Mon Sept 02 2013, 10:58PM
That is weird.
Have you checked to ensure the parts you are using are indeed the correct ones that are specified in the UD parts list? I know there can be big differences in specs between the same part number chips but from different manufacturers. Or some chips can be counterfeit.
Just throwing that out there as I have seen issues like that arise in other projects I've worked on.
Tue Sept 03 2013, 02:35PM
That is weird.
We are pretty sure that is not the problem. Kizmo uses the original board files and SMd components. I get the same problems with homemade single sided board and through hole components. Tried different manufacturers of some of the ICs, Kizmo uses the TL3116 comparator and I use the MAX913. Those two drivers are about as different as they can get :)
Sync
Wed Sept 25 2013, 05:50PM
Sync Registered Member #510 Joined: Sat Feb 10 2007, 09:28AM
At first, I am sorry that I could not write earlier, work and exams ate a lot of time lately.
As per Conners request I hooked Mads driver to two signal sources, the result can be seen here,
Traces from top to bottom:
  • Output to gate drivers
  • IC4B pin 10
  • Interruptor input
  • Input to comparator
From what I can see the comparator is triggering rock solid on the signal. There is the occasional extra pulse or glitch, but nothing major.
Unfortunately I cannot generate signals with controlable phase relationship to each other at this point but I'm shopping for an arbitrary function generator.
The next step is to setup a small loaded tank and see how this thing behaves when connected to a real circuit.
Kizmo
Fri Nov 08 2013, 08:49PM
FFFUUUUUUUUUUUUUUU
Now this is getting just stupid. What the hell i'm doing wrong with this thing?!
I went ahead and purchased 100% tested and working board from mr. Slawinski. This board has been used in his DRSSTC IV with great success.
My build is entirely new as well
- CM600 H-bridge
- 2 GDTs, 2.2ohm turn on and 4.4ohm turn off resistance, very nice gate waveforms.
- 1:33:33 cascaded feedback ct (gdt and feedback ct are same ferrite material)
This new build has _nothing_ common with my old builds and yet still it does _exactly_ same thing! Some burst lengths work just like they should, tank wiring is getting nice and toasty with perfect waveforms. We are looking at actual inverter output voltage vs primary current reading from feedback CT before burden network. In this picture, ON time was set to 96µs.
1383943659 599 FT144747 Aaa
Aaand then just couple ticks back, to 92µs and good old bzbzbbbpbzpbzpzbzpbz bpzbpzbbzpbzpzz is back!
1383943797 599 FT144747 Bbb
Now seriously. It has been almost 3 years, and countless tries with UD2.x and result is nothing but piece of crap!
I am really goddamn close to do something really destructive with these builds...
Hydron
Sat Nov 09 2013, 02:13AM
Take a look at this, it may be relevant to your issue: Link2
I know that I have seen some weirdness due to initial voltage on the cap at certain pulse-widths.
