  • Guests: 32
M.A.D. (32)
12/15 marko666 (58)
12/16 Will T (16)
12/16 william L (29)
smaller coils (and a 12MHz target)
Thu Nov 30 2006, 08:49PM
I did just th same but used zinc chloride instead of oil (wich is supposed to protect from and dissolve the existing oxide; I wasn't even close to soldering it!
I blame my weak iron and impure ZnCl2 (I left some carbon in it after I foolishly tried to mix it with wooden stick).
I've previously sanded a hell out of that piece but it still didn't work.
Not to jack the thread anymore..
Don't want to jack-a-thread anymore, my fault ill
Thu Nov 30 2006, 11:37PM
A Faraday cage is a very important piece of lab equipment when playing with high frequency coils. It saves EMI hassles and painful RF burns. So I don't have a problem with discussion of how to make one.
Aluminium is difficult to solder with ordinary soldering irons. I've never managed it: when I need to make electrical contacts to aluminium I always use nuts, bolts, and star washers. So if I was building a Faraday cage, I'd choose a different material. In fact, when I think about it, I'd just use an old microwave oven. It's a Faraday cage with a door that can be picked up at the kerb free, as long as there's not anything too vile inside ill
WaveRider, does the oven door seal work for 14MHz as well as microwaves? I don't know, I seem to recall that it's a choke joint tuned to the operating frequency.
Tom540
Fri Dec 01 2006, 01:42AM
Tom540 Banned on 3/17/2009.
I managed to solder a peice of wire to an aluminum tube. I used household oil on the tube after I sanded it. Then turned a fat tip iron all the way up to 800 degrees. It took awhile and I managed to get a good solder joint in one spot but honestly I would take Conners advice and just use something diffrent. It's not worth the effort. What about chicken wire? It's steel isn't it? That can be soldered if need be. Maybe make a wooden frame and wrap chicken wire around it.
teravolt
Fri Dec 01 2006, 04:49AM
use rivits every inch
WaveRider
Fri Dec 01 2006, 08:13PM
The microwave door should work well with a few simple modifications. I would strip the door seal area to bare metal and put copper braid or fine finger stock to make a good electric seal.
In my faraday cage, I used 1cm galvanised steel hardware mesh. Piss easy to solder and cheap as chips (I paid 7.5 euros for 5 meters x 60cms.)
Dr. SSTC
Mon Aug 18 2008, 09:11AM
Dr. SSTC Registered Member #1407 Joined: Fri Mar 21 2008, 07:09AM
that looks amazing matt! smile
Mon Aug 18 2008, 04:05PM
This is a bit old thread but BT's coils never stop to amaze me.
Herr Zapp
Mon Aug 18 2008, 11:43PM
Matt -
Interesting work, and nice looking.
Please confirm which of the coilforms shown in your photos is Teflon.
Regards,
Herr Zapp
Tue Aug 19 2008, 12:07AM
Herr Zapp wrote ...
So what type of plastic tube you use will seriously effect the performance?
Zorink
Tue Aug 19 2008, 03:15AM
Zorink Registered Member #1292 Joined: Wed Feb 06 2008, 04:09AM
All this is way over my head confused , but so far it looks amazing. I wish I knew how to make a 4 coil plasma speaker!
