  • Guests: 50
SA_Sparky (64)
SurfBum96818 (55)
Kabelnazs (45)
09/23 Weston (30)
09/23 TheMooseGoesMoo (33)
09/24 Rollingblackout (50)
Levitating wireless powered light
BigBad
Thu Aug 09 2012, 02:34AM
Dr. Dark Current wrote ...
"...then drop back down when power was restored"
The problem with strong magnets is that when they stick, the force needed to separate them again is remarkable. tongue
One crude and ugly trick that probably works is just to have an electric motor- once the power is restored you move the equipment above the ceiling up until the levitation circuitry can float it again and then lower it back down again.
BigBad
Thu Aug 09 2012, 02:57AM
Incidentally, as the power fails, if you've balanced it to give near zero stability current on a permanent magnet, you could just have a charged capacitor, and when the power starts to drop off, you just discharge the capacitor through the coil and use it to yank the bulb up to the ceiling. Conversely, when the power initially starts, you could give it a lob away by the same mechanism.
However, for that to work, the energy in the capacitor has to exceed the energy the bulb has by virtue of its potential energy in the magnetic field; so you would need quite a neutrally stable field shape; that is tricky to achieve.
Chip Fixes
Thu Aug 09 2012, 05:01AM
Chip Fixes Registered Member #3781 Joined: Sat Mar 26 2011, 02:25AM
Haha why not just leave the power on all the time and only switch the light on/off?
BigBad
Thu Aug 09 2012, 04:37PM
Because of power failures?
BigBad
Mon Aug 20 2012, 07:21PM
I bought a CFL and sawed the bottom off it to see the ballast, and found it's just a bunch of discrete components, which is good because i can repurpose it.
I also found a video of somebody driving a fluorescent wirelessly on the tube:
It looks like he just used an electronic ballast (which handly comes built into CFLs) a couple of coils, maybe some caps for the tanks, and (somewhat oddly) a transformer.
Not sure what the transformer is for, seems a bit bodgy, he presumably could have wound more turns on the receiver and changed the cap.)
Annoyingly there doesn't seem to be a circuit diagram, and there's still some stuff I don't completely understand about starting and how/whether that interacts with the transfer coils.
Pinky's Brain
Mon Aug 27 2012, 05:53PM
Is there any particular reason the guy from the video in the op and Marko use such high frequencies? Can this work at say 100 kHz as well? Dunno how it is in other countries, but at least over here LF is unlicensed for short range devices so it would have the advantage of being legal.
BigBad
Fri Aug 31 2012, 04:20AM
Pinky's Brain wrote ...
Yes, it can work at ~100khz. You need coils with more turns at lower frequencies, but I think 125 khz is one of the standards used for wireless power systems like this.
Pinky's Brain
Fri Aug 31 2012, 09:39AM
Or a bigger tank cap, a ferrite core would help as well, ideally you'd want a spherical form of E core (obviously the open ends of the coils would face eachother).
BigBad
Thu Sept 06 2012, 02:06AM
Ferrites tend to have too much iron loss.
Pinky's Brain
Thu Sept 06 2012, 09:54PM
At 100 kHz?
Any way they will also "focus" the field, improving your coupling factor and reducing the necessary circulating tank current and associated losses for a given power transfer ... kinda hard to predict which effect would win out.
