  • Guests: 43
williamn (48)
ReddyK (57)
Birdman (31)
12/14 M.A.D. (32)
12/15 marko666 (58)
12/16 Will T (16)
DRSSTC VI
Phillip Slawinski
Tue Jul 17 2012, 11:26AM
Phillip Slawinski Registered Member #1732 Joined: Thu Oct 02 2008, 02:34PM
Kizmo wrote ...
Great job Philip! :)
Gotta love that enormous pile of MMC you got there. Thats the way to go! There is absolutely no way one can overheat mmc like that cheesey
How high bus voltages are you using?
Quite a "pile" of MMC caps it is. The MMC consists of seventy-five capacitors in total. When you're spending this much time and money on a coil, it's best not to fool around trying to just scrape by. Indeed, this MMC is nearly bullet-proof. At the maximum of 3kA the peak voltage that the MMC sees is just below the AC rating on the caps (granted, that is a 60Hz AC rating).
We usually run between 700V and 800V on the bus. The bus capacitors are only rated for 840VDC, so 800V is the limit.
nixie
Tue Jul 17 2012, 03:33PM
nixie Registered Member #3908 Joined: Tue May 24 2011, 09:40PM
Hi Phillip!
I believe you have set a new goal for others to achieve with your stunning work of art. Clearly in the same league of your MPTCC.
And I imagine the doubler construction is just as meticulous. Maybe even including a smart auto-precharge circuit.
Congratulations! Hopefully your neighbors are friendly and supportive!
Regards, Jeff
Phillip Slawinski
Fri Jul 20 2012, 03:40AM
We ran the coil tonight, and finally started pushing it. We managed to get 16' 4" out of it, and then we had to pack it all up. Looks like it could still do more.
7607323236 15bb0f727e C
Fri Jul 20 2012, 04:14AM
Gorgeous! The coil is beautiful, the performance outstanding, and the photography is top notch too!!!
Sat Jul 21 2012, 04:00AM
Its pretty nice and all, but its really hard to see the lock-washers in the bridge exploded view... maybe you can work on that.
Just messing with you, of course. Obviously you did a superb job, and i know there is more to come!
Im very impressed with the spark length to toroid size ratio here. I wonder how much further it might be able to go?
Also noticing the 16 footers are much dimmer than the ground strikes. I do wonder how much the resistance of the brick post matters, or if its simply reaching the impedance of the arc that limits the discharge current, and hence brightness. Id have to think a bigger toroid might "fix" that.
StRyKeReYe
Sun Jul 22 2012, 05:02AM
StRyKeReYe Registered Member #5777 Joined: Tue Jul 17 2012, 03:34AM
I wondered about the Streamers too, I was noticing that when it went to Jack Hammering on the Concrete that they instantly became fatter and brighter, but at almost near the same time any branches that were not to ground also seemed to increase in Luminosity I'd like to look at the video again frame by frame to see.
As for a bigger Toroid are you going to let Phillip borrow Gigantors?
Sun Jul 22 2012, 08:00AM
Beautiful coil, great craftsmanship there :)
Phillip Slawinski wrote ...
The toroid is not spun, it's a foam core with Aluminum tape wrapped around it.
Could you please detail on how you made the foam core, smoothing, adding tape to be as smooth etc.
Phillip Slawinski
Sun Jul 22 2012, 07:52PM
Mads Barnkob wrote ...
I didn't actually build the toroid. Cameron Prince did. As I recall he had the foam core made by a company, and then shipped to him. He then applied the tape strip by strip, and used some sort of roller to ensure that it was smooth.
Matt Edwards
Mon Jul 23 2012, 07:46PM
Looks familiar ;)
Phillip Slawinski
Tue Oct 16 2012, 03:59AM
We ran the coil again this past weekend, and got even better results. 16' 9" (measured). We had to stop the run when the primary supports melted down!
In the video below, the breakout point is about 11 feet above the ground. The distance from the end of the breakout point to the post is 16' 9".
