  • Guests: 59
Kolas (18)
Dillon4DynamicHarmonics (41)
12/25 Kolas (18)
12/26 buxtronix (50)
+10KW induction heater
Tue Jul 17 2012, 08:15PM
You can't drive a parallel LC circuit with a voltage source inverter! :( It must be operating as a LCLR with the leakage inductance of the transformer as the matching inductor.
I've had a lot of success with pulse-skipping control for DRSSTCs and induction heaters. I dither the gate drive on and off using a flip-flop to switch only complete cycles, to avoid problems with DC offset.
Linas
Tue Jul 17 2012, 08:27PM
Steve Conner wrote ...
Yea, i guess i will try to make it with pulse skipping, what should not take much time with stm32f4 already up and running in discovery board
add inductor in series to transformer secondary coil and that should solve my problem ? (well, if it's problem)
just one question, will PLL be able to lock on resonance only with one impulse?
i guess i only need one sense wire for STM32F4 for period counting and one output for PLL to enable/disable (5 leg should work )
two ideas so far:
allow low/high signal and calculate frequency from that , at same time allow all impulse i need (lets say i allow 5, wait for 495, so that would be 1% of power, and use while loop for delay to get 495 , and allow 5 periods, wait 495 and so on, only problem it have to be spot on on turning on if LC circuit still have some juice left over.
second would be count LC circuit periods even then i have PLL disabled, for that i need to be able to see oscillations long time after PLL was disabled,so i need to check how long i have ringing in my LC circuit, and if i have more than 100 periods, what would be super :)
Kizmo
Wed Jul 18 2012, 04:13AM
My transformer coupled series resonant induction heater is nowusing 3 phase SCR stack for power control. Control voltage for SCR rectifier is generated from ivnerter output current. Simple and very effective. Driver is locked dead on resonance as its basicly just drsstc driver with interrupter jumped permanently on.
So far 12kW, lots of popped 16A fuses and no problems at all.
Wed Jul 18 2012, 07:03AM
Linas wrote ...
13 leg should be 2 leg, right ?
Nope, it uses phase comparator II.
Linas
Wed Jul 18 2012, 03:06PM
Uzzors wrote ...
Where is special reason for that or just for layout simplicity ?
Wed Jul 18 2012, 03:08PM
Sounds good Kizmo, what are you using to fire your SCRs? Did you get a commercial controller or make your own?
Kizmo
Wed Jul 18 2012, 05:04PM
Commercial, butchered from 15kVA UPS :)
Wed Jul 18 2012, 09:32PM
Linas wrote ...
Uzzors wrote ...
Phase comparator 2 causes no phase offset (0 degree shift) from the locked signal. Despite this you do end up with a phase shift in the end, which is adjusted by the potentiometer. I don't know how it works, but it does so quite well so I'm not complaining. I couldn't get a stable 90 degree lock using the XOR comparator.
Gabriel35
Wed Jul 25 2012, 06:40PM
Gabriel35 Registered Member #2310 Joined: Wed Aug 19 2009, 08:04PM
Hey !
Interesting conversation abou SCRs.
I'm wondering... How Can I use them to adjust the power of a Induction Heater?
I have the brick here rated for 400A...
It would be interesting!
Gabriel35
Wed Jul 25 2012, 06:46PM
Hey !
