  • Guests: 37
How to calculate resonant frequency of capacitor?
AuroraFlame
Fri Jul 06 2012, 05:18PM Print
AuroraFlame Registered Member #5566 Joined: Tue Jul 03 2012, 10:55AM
Firstly new member and first post here
I remember when I was a kid at school being told by one of the science teachers that the voltage difference between my head and feet whilst standing was over 100 volts. This has been known for hundreds of years and the voltage is about 100 volts per meter rising from the earth’s surface.
This means if you got a helium balloon, coated it in aluminum foil, attached it to a fine copper wire and let it rise 100 meters into the air you would have ten thousand volts between the end of that wire and ground!
Obviously the amperage is miniscule but in the early days of electricity it was shown that electrostatic motors could be run from this atmospheric electricity.
Ok so here is what I want to do and I am looking for some help from you guys if you would be so kind. I want to experiment with charging a large capacitor using the Earth as the power supply. Its just for fun really but here comes the difficult part (difficult for me anyway) I want to tune that capacitor to match the resonant frequency of the earths energy field which is about 7.86 hertz.
Obviously if the capacitor is tuned to resonate with the earth it will capture the maximum amount of energy. I know that tesla tried this although he used a coil instead of a capacitor. I just want to make a simple two plate disc capacitor.
I don’t know how to calculate the size of the capacitor that would have a resonant frequency of 7.86 hertz. I know that at such a low resonant frequency it must be large, perhaps over a meter diameter?
I am looking to use 2mm thick acetal sheet which has a dielectric strength of >50kv per mm therefore breakdown voltage is over 100kv. I will simply cut a single disc from this sheet and sandwich it between two aluminum discs. I will probably design the capacitor so it can be tuned once I get an idea of size range.
The experiment is obviously inexpensive and low-tech, the only difficulty being working out the size of the capacitor needed.
Technical data for acetal sheet can be found here Link2
Thank you for any help!
Fri Jul 06 2012, 10:24PM
The 100 V/m is a 'static' electric field,
consider it as direct current
the Schumann resonances are alternating currents,
with very little power
on its own an 'ideal' capacitor has no resonant frequency
resonance requires inductance and capacitance,
the tether/line/wire from the balloon would have inductance (about 1 uH/m)
but to get resonance at around 8 Hz quite large values of capacitance and/or inductance are required ( F = 1/2.pi.sqrt(L.C))
your wire would probably leak the charge back into the air due to corona
flying a tethered balloon 100m up requires permission (CAA etc.)
you would require a very large balloon to collect a useful amount of power
What do you actually want to do?
AuroraFlame
Sat Jul 07 2012, 12:13PM
That a parallel two plate capacitors don’t have a resonant frequency goes against what I was taught whilst at collage. I actually remember the lecturer setting us the task of finding the resonant frequency of a capacitor as a test. We simply used a scope and signal generator connected to the capacitor, adjusted the frequency until max amplitude wave was observed and noted it down as the resonant frequency of the capacitor.
As for the Schuman frequency I always understood them to be pulsed dc. The ionosphere is positively charged and the earth is negatively charged like two plates of a capacitor. The sun charges the earth capacitor up with charged particles until a potential is reached when a lightning strike occurs. This process occurs rhythmically and thus the field around the earth builds and collapses rhythmically.
Antonio
Sat Jul 07 2012, 01:18PM
These concepts are quite confuse. A capacitor really resonates with its own inductance, this is a known problem in high-frequency circuits, and is measurable. But the resonance occurs much above the normal frequencies where the capacitor would be normally used.
The Schumann resonance occurs simply due to the time that an electrical signal takes to propagate around the Earth. Any lightning strike excites it, but it is a low-Q resonance, difficult to observe. Lightning does not occur due to charges received from the Sun, that would not affect anything on the ground due to the Faraday shielding effect of the atmosphere. Lightning occurs due to triboelectric effects in storm clouds.
Pinky's Brain
Sat Jul 07 2012, 03:18PM
Antonio wrote ...
Presumably rain figures into it as well at some point, I've always imagined ground strike lightning like a Kelvin water dropper writ large.
Carl Pugh
Sat Jul 07 2012, 05:17PM
Carl Pugh Registered Member #1064 Joined: Tue Oct 16 2007, 05:04PM
Maybe I'm getting old and cautious, but:
They say quite a few people have been killed while flying kites using wires. (Benjamin Franklin's kite experiment)
I worked with an engineer who told the story that they had an antenna on the roof that was connected to a cable in the ceiling. He came in one morning and the cable was moving around. He grabbed the cable and was knocked across the room. The put a meter on the cable and measured 10,000 volt.
WHAT YOU ARE TRYING TO DO IS DANGEROUS. DON'T DO IT WITHOUT A LOT MORE RESEARCH.
Sat Jul 07 2012, 06:59PM
Carl Pugh wrote ...
That would make an excellent stock reply to 90% of posts on the forum.
However it is true that since Ben Franklin first flew a kite in a thunderstorm, many people have been killed trying to replicate the experiment.
Static charges on radio antennas are a well known phenomenon. Every ham radio rig I've poked around in has had some sort of device for dissipating them to ground.
The energy in the Schumann modes comes from lightning strikes, of which there are about 120 per second averaged over the whole world. I believe the general consensus is that it's too small to be worth "harnessing".
AuroraFlame
Sun Jul 08 2012, 05:13PM
I am aware that such experiments could be dangerous but only during bad weather, during fine sunny weather that would not be so.
Here are some electrostatic motors which are running off electricity collected from weather balloons. Link2
"You can measure this voltage with an earth-field antenna—a wire with a sharp point at the top to start a corona, or with a bit of radioactive material that ionizes the air in its immediate vicinity. Near the earth, voltage is proportional to altitude; on an average day you might measure 1,200 volts with a 10-meter antenna"
I'm not really interested in making motors however, I just want to see how fast a large capacitor would charge using this setup and how big the sparks can be got from this.
Carl Pugh
Mon Jul 09 2012, 04:58PM
Would you bet your life that the preceding statement is correct? You are:
radiotech
Fri Jul 13 2012, 06:13AM
Circuits have two ends. Could you sketch your earth-balloon circuit showing the flow paths
and indicate the EMF source.
