  • Guests: 55
12/02 Hax (40)
12/02 PhilGood (62)
12/04 Sulaiman (71)
FPGA TC driver board
Goodchild
Sat Jul 28 2012, 05:06PM
Steve Conner wrote ...
Mike: The FPGA I'm using also supports the SPI PROMs. I weighed the cost saving of the 3rd party SPI PROM against the extra development time needed for me to figure out how to program it, and the Xilinx part won. The instrument it's used in sells for about £20k.
Eric: You have a good point smile IMO, Tesla coiling is a way for electronic hobbyists to do something adventurous and push their limits. Learning about FPGAs could be a part of that. Also, the big boys all use FPGAs to control their electric trains and so on.
Anyway, all I want out of it for the time being is a multiplexed fibre data link. smile
I can see doing it, just to say we did is a very valid reason for doing it! Also a great way to learn more about FPGA's.
One more question from the peanut gallery, what is the max prorogation delay that can be achieved with FPGA's running a Tesla coil algorithm? I ask because I'm curious of the upper frequency limits that the controller could run at. Would a coil running in the MHz range be feasible?
Sat Jul 28 2012, 06:11PM
If you're using a Prediktor or a PLL, propagation delay isn't an issue as it can be compensated. However, the system would probably be synchronous: it would run off a clock at say 50 or 100MHz, so the gate drive waveforms could only change state on 20 or 10ns boundaries. That would result in timing jitter relative to the Tesla resonator's resonant frequency.
