  • Guests: 39
Seek guidance to step-down 1kV pulse to 12volts
brandon3055
Mon Jun 18 2012, 11:51PM
you could try the board from an off the shelf cfl it would be easier then ordering one and maby you've got a dead one sitting on a shelf somewere? i know i do
GammaRay
Fri Jun 22 2012, 10:53PM
GammaRay Registered Member #5323 Joined: Fri Jun 15 2012, 02:14PM
Reference to the above schematic posted by Antonio, for maximum efficiency, what diode is suggested for D1?
Antonio
Sat Jun 23 2012, 01:32PM
I have a similar circuit working, but don't have it here now to see the diodes. I used a 3 kV regular (slow) diode for D1 and a fast diode for D2. Without D2 the circuit works too, but it works better with D2. Apparently D1 takes a too long time to switch off, and a significant current returns through the inductor after the charge of C2, discharging the capacitor significantly. With D2 this doesn't happen.
